Home > Technical > Wiper issues (changed everything) still problems! HELP!
Page 2 of 2 <12
Check there isn't a high resistance to the earth, the earth is common so could affect a lot of things. KEEP CALM AND Drill ON
Post #593549 16th Jan 2017 4:45pm
dorsetsmith
have check these against 91 90 wiring ok, fuse box layout will difference but wiring colours are same and pin out same to the relay and motor too
Post #593555 16th Jan 2017 5:45pm
Martin
Site Admin
Have you got a multimeter?
There are some tests you can do if you have.
Let me know Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #593859 17th Jan 2017 4:31pm
gilarion
Just a thought, you did obtain the correct - New Lucas stalk! as for a 1992 Defender there are two types one gives intermittent and one does not. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #593863 17th Jan 2017 4:46pm
Martin
Site Admin
Difficult to mix up the stalks as the two different types won't fit the indicator switch assembly bracket without modifying a clearance hole.
(I've got an intermittent stalk on the 1988 soft top)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #593865 17th Jan 2017 4:52pm
FLX1S
United Kingdom 1992 Defender 90 2.5 n/a Diesel SW Bonatti Grey
Thanks how do I do that?
Post #595552 23rd Jan 2017 11:06am
FLX1S
Let me know Smile
Hmmm how can I tell? the plug was correct...
Post #595553 23rd Jan 2017 11:07am
FLX1S
I'll double check!
Post #595554 23rd Jan 2017 11:08am
Page 2 of 2 <12
