Home > Maintenance & Modifications > Solenoid Wiring - Help Needed |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 |
Well it looks from the instructions the positives + from each battery to the large terminals 1 & 4, I guess its earthed through the body ?
My winch has + and - fat cables both back to battery though. Pom |
21st Sep 2011 7:17pm |
christyler Member Since: 10 Dec 2010 Location: Cork, Ireland Posts: 67 |
Just ignore the "+", that only matters if your solonoid has aux contacts, and yours dosent.
the two big terminals are just a switch (they join together) and the small ones are the coil, the coil will work any way round. i would put a diode across the coil terminals as well if i was you, it stops any nasty spikes caused by back emf getting to your electronics when the coil is energised. |
21st Sep 2011 11:34pm |
MD5 Member Since: 02 May 2011 Location: Italy Posts: 143 |
Thanks for your assistance!
To recap, the wiring scheme of the new Albright solenoid is the same as the factory one ? Which kind of diode you suggest ? Do I need to put the cathode on the left or right small terminals ? |
22nd Sep 2011 4:32am |
ethanicus Member Since: 11 Jan 2013 Location: Surrey Posts: 94 |
Hi All,
I am just about to do the same, what diode should I use? I have some standard 12v 5w zener diodes to hand, will they be ok. Cheers |
15th Jan 2017 7:27pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20492 |
MD5 - Anode - Positive. Cathode - Negative.
I was looking at this the other day, however, it's very confusing as to which diode to use. There are Durite versions not on eBay, that are mini fuses that go in mini fuse holders. Many seem 100v or 150v, which I see as pointless as surely you'd not want any voltage spike above 50v max.... I don't mind admitting that I'm not an expert as to all the different diode types and equirements. I was thinking of fitting similar to the OP but for an ignition switched Live feed up to 100A Durite HD make / break relays have not diode built in like some smaller ones do. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
15th Jan 2017 7:37pm |
The flyback diode does not literally protect against voltage spikes, but it prevents spikes being generated when the coil is deactivated. Therefore it does not have to be a big diode of high voltage, a generally used type like the 1N4001 (50V/1A) is OK. Here is a good explanation how it works. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
15th Jan 2017 8:09pm |
VeeTee - This is what I was looking up last night.
One reason I'm also going to change my spot light Relay over to a type with in-line diode built in. I don't like the idea of fitting LED headlights with EMF creating spikes up to nearly 200v is possible. That is fine fir mini relays but HD types seem to have no diode built in and seem to have a 300mA coil which is larger thus creates even more EMF current to dissipate. Would this suit fitted parallel in this instance for me and the OP? http://www.ebay.co.uk/itm/1x-Durite-Diode-...SwQItT6L1P There is a 10A in-line version too, but typically they are fitted in parallel with the coil not in-line. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
15th Jan 2017 9:08pm |
thanks guys, just what I needed.
16th Jan 2017 8:55pm |
I am not sure about this, but I think the current (spikes) generated when the coli is deactivated is logiccally about the same or generally much smaller than needed for activation, thus < 300 mA. It's about volts, not amps with spikes, if the same energy is released within a split second, then with a coil having a small resistance gives spikes with high Voltage low current. I can not explain it in full detail, but here is some more interesting info about the subject. Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
17th Jan 2017 7:20am |
