Home > Puma (Tdci) > Oily sludge AFTER intercooler?
Manxie
Isle Of Man 2008 Defender 110 Puma 2.4 HT Keswick Green
Hi gents, I was changing out my intercooler and hoses today in prep for my Bas remap, and the inside of the OUTLET hose that runs up to the inlet manifold from the intercooler was dripping wet with what looked like heavy wet oily sludge? There was a minimal fairly dry amount of residue on the inlet to the intercooler, so I don't believe it's from the crank case breather. So the only thing I can think of is it's running back from the EGR pipe that goes into the MAP sensor pipe? But why would it be sludgy wet and oily?? Is this an indication of a problem? I'm also fitting an oil catch can on the breather before the intercooler along with the other new bits....
Post #593150 15th Jan 2017 4:45am
LR90XS2011
i believe this is just the crankcase breather oil/mist that has condensed in the inter-cooler as the air flow would pretty much stop things going in the other direction, well worth cleaning it all out, and a good advert for a breather oil separator like the Mann Hummell ones, some horror stories on various forums re this on other cars DEFENDER 90 TDCI XS,
Post #593169 15th Jan 2017 8:38am
Manxie
Ah ok, condensed, that makes sense. So because the air charge is heated, it's able to keep oil mist vaporized and in suspension, then once the air charge is cooled through the intercooler, then it falls out and gathers on the discharge, that's a relief, thank you. Now I'm extra happy to befitting the oil catch can on the breather. I looked at the Provent, but decided to go for this unit based on I wasn't keen on changing the filters. http://www.42draftdesigns.com/stealth-oil-catch-can/
Post #593176 15th Jan 2017 10:09am
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
any one used one of these breathers ?
Post #593186 15th Jan 2017 10:56am
Sadi
Namibia 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
Choices ..
Nice info here on the Provent product:
http://asgard-engineering.com/land-rover/
Manxie - any feedback on your catch can - it also seems a quality product.
Post #613847 1st Apr 2017 7:29pm
