Home > Puma (Tdci) > Oil level in the sump (Installation of electric oil heater)
Alexke
Belgium
how high is the oil level in the sump?
I installed a Oil heater and I am afraid I installed it too high
the orange square marks my installation.
Thanks in advance! Discovery 4 SDV6 Landmark
F31 320dA Msport xDrive
LR Defender 90SW TD4 Stornoway grey
320d E46
E70 X5 3.0d Sold!
FFRR TD6 - Sold
Post #592608 12th Jan 2017 10:57pm
Alexke
Belgium
Today I put the heater on a timer at 6:30 till 8:30.
Oil pan was around 14c and the ambient temperature was -3c.
Puma started better with less smoke !
I call win, but I am considering an aditional 250 watt pad. Discovery 4 SDV6 Landmark
320d E46
E70 X5 3.0d Sold!
FFRR TD6 - Sold
Post #592887 13th Jan 2017 7:40pm
mk1collector
Any pics of the install? Ray
My build thread
Post #592888 13th Jan 2017 7:55pm
VeeTee
Netherlands
Wouldn't it be more effective to install an electric heating element in the cooling system? Some have built in little impeller pumps so the the heated fluid is circulated and the heat is better distributed to the engine... Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #592894 13th Jan 2017 8:17pm
Alexke
Belgium
I will after the snow melts Razz
A water heater will be more complex and expensive , also it uses more energy then this.
2Kw vs 250watts
The big advantage to the water heater is that the top of the engine and the interior gets better heat.
but your 8 liters of oil in the sump is still thick and cold.
It is the most easy way to preheat the engine. Discovery 4 SDV6 Landmark
320d E46
E70 X5 3.0d Sold!
FFRR TD6 - Sold
Post #592955 14th Jan 2017 12:24am
If I were to fit a water heater again, I'd go for the 7 design 240v heater, heats the water jacket and pumps around the engine all for about £100 .. you need mains but a significant saving over a tried and tested webasto
Post #592972 14th Jan 2017 8:51am
ob1conobe
United Kingdom 2014 Defender 90 Puma 2.2 HT Alpine White
How does this link in with regard to a Webasto (or equivalent) system. I thought that was supposed to warm not only the engine but the cabin also? Is that correct?
Post #593003 14th Jan 2017 1:34pm
