![]() | Home > Maintenance & Modifications > Can I lower my side runners? |
nick345345 Member Since: 05 Dec 2016 Location: Dunbar Posts: 71 ![]() ![]() ![]() |
Hi there,
I've recently fitted TMD side runners to my 110 (http://tmdtuning.com/shop/tmd-black-side-runners-90110/). They replaced the standard fold down side steps. I really like the look of them, though they are quite high and quite close to the sills, making them hard to actually use. Has anyone ever managed to modify side steps to lower them and potentially move them out from the sill a bit. I'm thinking of lowering by a couple of inches and out by an inch. Appreciate that will reduce ground clearance and increase the width, but I don't think that's a problem for me. Just wondered if there was a kit or something? Or if I'll need to find a friendly welder to modify them for me. Thanks in advance, Nick |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1042 ![]() ![]() ![]() |
I've had the same problem on 2 successive 110s with factory fitted steps. The 1st 110 didn't have any chequer on the sill so the paint rubbed down to bare metal. Be interestign to see if something can be done.
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1443 ![]() ![]() ![]() |
Hi Nick.
Provided you don't need the runners to support the weight of the vehicle, by the sound of it you don't, then you could make some brackets to reposition them. A 3 or 4mm flat plate bolted onto the existing mounting holes, with similar holes drilled further up, should do it to drop them down. Moving them out could be a bit trickier, depending on how much. I wouldn't be happy to do this if there's chance of them grounding out offroad. It should be fine though to take the weight of someone using them as side steps. Before you fit them, take the end caps off the tubes and rust proof the inside with waxoyl or Dinitrol. These type of steps, both genuine and aftermarket, are notorious for rusting from the inside out. I once looked at modifying side runners to lift them up for more clearance and use them as "rock sliders" That would have required cutting and welding, so decided against it. The standard rails are also too weak (thin wall tube) and wouldn't have lasted long if used like that. Hope that helps. |
