Home > Expedition & Overland > Unbraked Land Rover trailer axles?
Manxie
Isle Of Man 2008 Defender 110 Puma 2.4 HT Keswick Green
Does anyone have a lead on where to source unbraked LR trailer axles or hubs? I'm wanting to modify a standard box trailer to take LR wheels. I've seen the heavy duty 6.5 PCD braked versions, but I was hoping to keep it lighter and simpler...
Post #591459 8th Jan 2017 10:15pm
excossack
Best I could google at the mo.
http://www.autoandtrailer.com/trailer-stub...ed-6-5pcd/ 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #591975 10th Jan 2017 10:10pm
That's a very interesting link ^^^^
Was the OP looking for this or something more heavy?
My trailer is a P8 Ifor on flotation tyre's, as the 90 is quite high the trailer does sit a bit nose high.
No so much as it's unsafe and is quite okay for a light trailer, but could ideally sit level.
Fitting axles like those would give the trailer a lift, issues would include mud guards would be a problem. (Too small.)
Pair of boost alloys, nuts, locking nuts & KM2 tyre's. (They'd have to match!)
Carrying a spare would be an issue.
Add the cost of axles, although type approved for load capacity suitable.
All together would be super expensive indeed. GBR
Post #591981 10th Jan 2017 10:21pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Buy an old horse/livestock trailer and use the axles probably be cheaper 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #591982 10th Jan 2017 10:24pm
muddybaldboy
Wales 1999 Defender 110 Td5 HT Chawton White
pm sent Thumbs Up He who dies with the most toys...wins!
Post #591993 10th Jan 2017 11:01pm
Bushpig
Wales 2012 Defender 110 Puma 2.2 SW Alpine White
Not sure if a LR axle will fit your trailer...
I chopped a 110 HCPU into a trailer and removed all the internals of the diff & axle.
 Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #592010 11th Jan 2017 5:31am
Retroanaconda
Bear in mind that any weight you add will diminish your available payload, so replacing a relatively light beam and Indespension unit type axle system with a far heavier LR axle or LR hubs could be a problem depending on how much of the payload on your trailer you regularly use.
Post #592141 11th Jan 2017 1:54pm
Bushpig
Retroanaconda, indeed you are correct about reducing the payload of the trailer.
But I've found that having the LR axle and hubs as 'unsprung' weight, the trailer is much more stable (especially when not fully loaded) when on the gravel roads around Botswana & Namibia.
I'm also currently changing the springs to standard rear 110 ones to help with the stability. Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #592476 12th Jan 2017 3:01pm
Manxie
Thanks very much for the link, that's great. Also it's looking like MBB might be able to help out with a pair 👍
Post #592819 13th Jan 2017 2:53pm
