Home > Maintenance & Modifications > Folding table fitted
Page 2 of 3 <123>
leeds
Now on the 4x4overlander webshop
http://www.4x4overlander.com/product/nakatanenga-folding-table/
I did get some of the things I threatened to do done over Christmas if you include Twelfth Night Very Happy
Regards
Barbara
Post #590735 6th Jan 2017 4:49pm
Bomber82
Italy 2009 Defender 110 Puma 2.4 SW Zermatt Silver
Very nice Thumbs Up Matteo
Defender 110 Td4 SE MY 09
Post #591763 10th Jan 2017 9:38am
JamesF
United Kingdom 1989 Defender 90 2.5 TD HT Baltic Blue
Looks great... I want one!
Post #592168 11th Jan 2017 4:44pm
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
Shocked didn't think they would be that price .
But look very good .
Post #592169 11th Jan 2017 4:46pm
newton-tony
United Kingdom 2014 Defender 110 Puma 2.2 USW Firenze Red
I had been doing some searching around the forum for a foldable table for the rear door. This one was around £60 from Amazon and so far very pleased with it - very quick and easy to fit, with some M6 short bolts and load spreader behind the trim.
Post #843173 11th Jul 2020 7:18pm
Tr90
United Kingdom 2000 Defender 90 Td5 CSW Alveston Red
Do you have a link to the amazon item please
Post #843182 11th Jul 2020 8:09pm
newton-tony
You may spot not initially intended for a Defender, but fits well 😉
https://www.amazon.co.uk/dp/B07GWYMKTF?ref=ppx_pop_mob_ap_share
Post #843186 11th Jul 2020 8:32pm
Tr90
Nice one. Thank you
Post #843195 11th Jul 2020 9:16pm
Argee
Hi,
Nice solution - can I ask, do you have to assemble it? If so, could you put it together so that the lip was on the inside? Reason being I’d like to use the slots for molle bags.
TIA
Rich
Post #843201 11th Jul 2020 9:47pm
newton-tony
You don’t, but I would say easy to take apart and re-assemble how you prefer (2 nuts and bolts only)
Post #843209 11th Jul 2020 11:05pm
T3
That seems a really good fit! Could you elaborate on how you fitted (just through the plastic trim?) and what you used as a load spreader please?
Thanks!
Post #843262 12th Jul 2020 10:29am
newton-tony
Hi T3.
I thought I would try just fixing just through the plastic trim (given the panel is secured by the 4 grab handle screws plus other push fixings). So far, all is good and used several times for cooking etc.
You do get a template in the pack for positioning the fixing holes, but I just positioned the table to make sure the rear door would open and close, then just drilled 6mm holes in the plastic trim.
I just used some MDF offcuts I had for the load spreaders (see photo), as a prototype to see if simply bolting through the plastic trim worked (3 x black M6 short bolts and washed on each side). This worked fine and so far I have not had a reason to change or replace with anything else.
I am sure penny washers would also work. I did also use some double sided foam sticky tape on the table supports, but again not really needed.
Hopefully clear, but let me know if any other questions.
Post #843369 12th Jul 2020 6:22pm
keith
Genuine table is around $240 in my searches but found aftermarket at £61.
Ordered Thumbs Up
Keith
Post #843371 12th Jul 2020 6:27pm
T3
Thanks, Newton-Tony - that's very useful! It's going on my list of things to do.
Cheers.
Post #843444 13th Jul 2020 9:58am
Argee
Got mine fitted yesterday, added some nylon spacers to keep it vertical and not lose any space in the net pocket.
Had to reverse the bolts shown in first pic as they rubbed on the table.
Added some Mud molle bags and my axe, worked out well, cheers for the tip on the table!
Post #844830 20th Jul 2020 10:36am
Page 2 of 3 <123>
