Home > In Car Electronics > Rear door switch
mse
Rear door switch
Am i right in thinking, if i take a feed from the rear door switch purple wire via a 3 switch i can wire it so:
On: On
Off: Off
On: On when door is opened
(this is for my interior lights already wired)
I seem to recall the purple wire out of the switch is a live not an earthed switch? Mike
Post #591045 7th Jan 2017 6:48pm
Can't remember colours.
But there are two lives and and earth.
One is the AS10 live
2 perm live.
Earth, door switch triggered and earth switched.
This gives you on the lights, on constant, door switched on, off completely.
If you wanted to mimic this in something else providing load is with in standard allowance you can solder to light fixture pins like I did.
Then what ever you are running off of the feeds you can mimic and use all features of the interior lights.
There isn't a need to tap directly into the wires, if it all goes Pete tong (which it shouldn't!) you could just replace the light fixture.
Fit an in-line fuse and you still retain interior lights. KEEP CALM AND Drill ON
Post #591061 7th Jan 2017 7:34pm
Here is an old pic:
You can see the feeds, the light fixture I no longer use but you can solder onto the pin feeds each side of the light once you've identified the live pin and earth.
Then you can mimic and use the same switching for the lot. KEEP CALM AND Drill ON
Post #591065 7th Jan 2017 7:39pm
mse
Thanks - i think the feeds for the rear lights run down the back anyway so i could tap into them there, although thinking about it, the reason i wanted to use the rear door switch was to only have the rear lights on when using the rear door eg open the front door and its just normal LR lights, rear door its normal lights plus my lights
Ill have to go an do some testing me thinks Mike
Post #591135 7th Jan 2017 10:04pm
Cupboard
The wire that goes to the rear door switch doesn't actually carry any load, it's just controlling the 10AS.
It's also in common with the passenger doors (or I think it is, control-wise they're common).
I would be reluctant to mess with it, whilst it does undeniable short to ground when the door is open, putting something in that relies on that fact to switch it could end up confusing or breaking the 10AS. If you wire a light in to it then when the door is closed the light will pull it up to 12V and I've no idea what the 10AS is expecting. It may not cause any issue at all of course.
Post #591310 8th Jan 2017 4:45pm
dorsetsmith
Post #591338 8th Jan 2017 5:37pm
