Home > In Car Electronics > Heated mirror/front screen switch issue
drinkdrinkdrop
Hi
In the process of adding heated mirrors to my td5. I decided as I wasn't going to install a heated front screen and the switch would fit in the standard dash I'd use the switch for a heated front screen (YUG000460LNF) to turn the heated mirrors on and off.
unfortunately it seems the switch will only power the mirrors when held in.
looking at the wiring for a heated front screen it appears the switch gives a pulse to a timer relay which then energises the relay to power the screen. Which I think leaves 3 options
1. Add a timer relay and wire it up per the standard front screen wiring
2. replace the standard relay with a latching/impulse relay
3. get a new switch body and connector from a latching type switch and swap the fascias
Any thoughts on those options, whether they will/won't work an better options?
Thanks in advance
Mark
Post #591250 8th Jan 2017 12:04pm
Martin
Site Admin
Cheapest and quickest option is 3 - the Puma heated seat switch will do what you want.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #591257 8th Jan 2017 12:13pm
jr1104
United Kingdom 1998 Defender 90 300 Tdi CSW Rioja Red
I'm in the process of planning something similar (one switch for heated front/rear/mirror). In choosing the relay(s) for this, a timed one made more sense for functionality? That way I press it once, and I don't have to remember to turn them off again after driving for a while.
Post #591490 9th Jan 2017 6:21am
Martin
Site Admin
PRC6796 is the original fit timer for the front screen, it normally operates a single relay for the front screen but you could add extra relays Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #591510 9th Jan 2017 9:34am
Martin
Site Admin
Hmm, they used to come up on eBay regularly but seems that's no longer the case Sad  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #591511 9th Jan 2017 9:37am
drinkdrinkdrop
I'll go with that then, thanks for your help
Post #591528 9th Jan 2017 11:11am
boode
England 2003 Defender 90 Td5 HT Rutland Red
Slight Hijack of thread
I would like to put heated seats in on a timer - 10 mins heat at start of journey
If I use the front window switch to a GLR10 timer then a relay - will this work
The kits from mobile centre seem to have two relays and the orange timer - why two relays
Any chance of someone showing the wiring required ?
Post #594538 19th Jan 2017 6:50pm
