Home > Maintenance & Modifications > Headlights
Page 4 of 4 <1234
Just re-read through this thread - apologies for so many typos! iPad tends to like to type for me and then gets it wrong.
Today, I've purchased Noldens in black with position lights along with the little loom things for the sidelight.
And two Land Reigziger looms, with plastic connectors. (As suggested, no point in Ceramic unless the load is 100w Halogen.)
55w is all that is road legal in Halogen head light anyway and LED less heat produced.
The Land Reiziger looms are out of stock, but I expect they can sort that out and no immediate rush.
My aim is to wire back to the battery with a good grade permanent live. Probably 2mm thinwall or similar, inside a small bore un-slit convoluted tube.
Fit an in-line fuse & holder near the battery for now, at a later date fit a BlueSea fuse box, then I'm sorted.
Accessible, safe, and reliable with the voltage gain and load taken off the switch.
Mr. Green ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #590494 5th Jan 2017 7:48pm
ericvv
Why going through the trouble of wiring through the firewall all the way to the battery if you can wire to a permanent live on the alternator in the engine compartment where you need to be anyway? That alternator permanent live is in direct contact with the battery anyway, so why bother making it more difficult? No advantage at all.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #590500 5th Jan 2017 7:59pm
Fuse placement is better access and avoids messing around with the alternator.
Just my preferred method to keep everything located where I want it.
I've got a feed coming through anyway through the bulkhead so I can easily follow with another. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #590540 5th Jan 2017 9:13pm
Page 4 of 4 <1234
