Home > Maintenance & Modifications > Td5 dash
boode
England 2003 Defender 90 Td5 HT Rutland Red
Td5 dash
Simple question - is it possible to fit standard type Td5 switched in the recessed section of the dash below the radio ?
Not sure if there is enough space as the switches are fairly long
If any one has done this - any pics ?
mcma1 is selling switch holders so it could look neat
Post #590172 4th Jan 2017 7:22pm
jrule
United Kingdom 2000 Defender 90 Td5 CSW Oslo Blue
I believe this can be done, I think Martin has done for heated seats…depends if you have headlight leveller switch currently
Post #590173 4th Jan 2017 7:39pm
boode
Only a USB where the leveler fits
Post #590175 4th Jan 2017 7:44pm
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
There should be enough room below the radio for switches and enough room behind too.
Heres my dash I modified before I changed to a puma dash. The switches below the CD player worked perfectly and nothing fowled them.
I would however, just to be safe, check there is enough room behind yours. As mine was a 300 with complete td5 dash, although on our td5, there doesn't seem to be much where those switches are.
Post #590325 5th Jan 2017 8:35am
Mo Murphy
I've moved my radio downwards using a Mud panel. If my radio fits there then you can be quite sure your switches will 😊
50 Shades of Pennine Grey
Post #590336 5th Jan 2017 9:47am
