Home > Technical > Grade of bolts used on axle and steering compnets on TD5 110
rodspink
Hi folks.
Wonder if anyone can tell me the grade of bolts used on supension parts. Likes of the rear axle a frame, radius arms, trailing arms , panhard rods etc.
I think the aframe ones are 10.4 but not sure of the rest. I am away to order bolts for a rebuild and obviously want to get it correct.
Even better does anyone have a list of what is required for a TD5 110
Rod.
Post #589744 3rd Jan 2017 2:15pm
Retroanaconda
Think some of them are 10.9 grade.
The part numbers will tell you the sizes and lengths in most cases, and Google will give you the result for the others.
Post #589752 3rd Jan 2017 2:59pm
dorsetsmith
Post #589776 3rd Jan 2017 4:29pm
NormanD
England 2015 Defender 110 Puma 2.2 USW Santorini Black
The grade of bolt is usually forged onto the top face of the Hex, clean the existing ones off with a wire brush and identify the grade
Have a look at this US identification chart - https://www.boltdepot.com/fastener-informa...chart.aspx NormanD WE191
2015 110 XS Utility
2014 VW Caravelle 180 Executive
Post #589780 3rd Jan 2017 4:39pm
rodspink
Thanks folks.
Post #590625 6th Jan 2017 8:52am
