Home > Technical > Alarm Sounder - can you silence it
chopcat
Wales 2000 Defender 90 Td5 CSW Java Black
So I have tried to sort out the intermittent fault that sets off my alarm without much success.
I have changed all the door and bonnet switches and disconnected the volumetric sensor.
I use the alarm to activate the central locking. SO the question is can one disable the sounder but retain the function of the alarm to operate the locking.
Goodness knows shat after 17 year has now started to give this problem!
Trevor
Post #589376 2nd Jan 2017 8:58am
grafty99
It could be a poor connection between the BBUS and the loom? I would check for corrosion or a break in the wire. The sounder might think it is being unplugged and therefore go off?
If you turn the key in the door it should operate the central locking without the alarm I think Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #589383 2nd Jan 2017 9:24am
