Home > Maintenance & Modifications > Brake fluid change
ibexman
Brake fluid change
Does anyone flush theirs ?
Post #589202 1st Jan 2017 3:11pm
dorsetsmith
yes and clutch at the same time
Post #589206 1st Jan 2017 3:27pm
Mo Murphy
Yup, push it through with new stuff.
50 Shades of Pennine Grey
Post #589217 1st Jan 2017 4:16pm
ericvv
Brake fluid is hygroscopic, so absorbs water. Therefore irrespective of whether you drive few or a lot of km, brake fluid should be replaced every two years on every car.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #589248 1st Jan 2017 6:04pm
agentmulder
Kuwait
Yes, I changed mine recently Solved the bowel problem, working on the consonants...
Post #589261 1st Jan 2017 7:12pm
lohr500
Did mine as part of the three year service in the summer.
Picked up a tip from the forum on removing most of the old fluid from the reservoir 1st to save wasting a load of new fluid.
I think it's good practice and it helps to prevent the bleed nipples from seizing up as well.
Post #589268 1st Jan 2017 7:35pm
Litch
Yep, regular as clockwork.
With a pressure-bleed kit it is a quick & simple operation (used to use an Eezibleed but have had a Sealey VS820 for a few years now and it is excellent). ONE LIFE, GET IT!
Post #589285 1st Jan 2017 8:13pm
