Home > Puma (Tdci) > Latest random fault - this time indicators are sketchy |
31st Dec 2016 8:00am |
Thanks for that, I found the circuit on page 60:
Click image to enlarge They've left out internal info on both S121 and J100, what do these parts do? 'S121' gives no hits when searching the WSM or the connector manual - I'm guessing it's the hazard switch in the centre panel, but J100, where and what is that doing? In general, I find the Defender documents make it impossible to easily cross reference parts not only between documents but internally also. The manual helpfully states:
Guess I'll just follow the cable colours to the parts and (hopefully) nut it out from there... Solved the bowel problem, working on the consonants... |
31st Dec 2016 5:24pm |
S121 =
J100 is light on your instrument cluster correction |
31st Dec 2016 5:40pm |
Thanks!
How did you know what J100 was? So by 'instrument cluster correction' - do you mean a connection to the binnacle? Question: Are the lights in the binnacle (the driver's 'indicator indicators') fed by the same circuit that the actual indicators are fed by, so that if I see instrument lights I know that the actual indicators should be seeing 12V also? Meanwhile, after jiggling the cables at the back of the hazard switch (S121) the fault is at least consistent now - everything works as it should but upon standard indicating there is a slight delay to get the indicators started, also the little trailer light icon is on for the duration of this initial delay. A bit inconclusive.. It would be great to know what is meant to be happening inside S121 and J100, it's a bit hard to nut out at first and second glances. S121 in particular seems to tie quite a bit of functionality together. Oh and happy new year - when it gets around to you (it's 7:48AM on the 1st here and I'm at work ) Solved the bowel problem, working on the consonants... |
31st Dec 2016 6:47pm |
So by 'instrument cluster correction' - do you mean a connection to the binnacle? Yes, bad English i no phone in dark in field waiting parts turn-up. to fix generator that problem sorted now, back on standby
31st Dec 2016 7:06pm |
Both at work
I'm on tech standby for a large venue, if everything is set up well (as it appears to be) then I've got nothing to do but look at Defender manuals Solved the bowel problem, working on the consonants... |
31st Dec 2016 7:20pm |
Since discovered this is normal! Never noticed it before Must have bumped the hazard switch then, and bumping it again fixed it - very 'defender' - happy happy Solved the bowel problem, working on the consonants... |
1st Jan 2017 5:13am |
