Home > Maintenance & Modifications > Diff pinion height
Defendermatt
United Kingdom 1989 Defender 90 Other SW Bonatti Grey
Diff pinion height
I'm replacing the diff pinion bearings on my 90. If I re use the old shims will I still need to set the pinion height?
Post #588866 30th Dec 2016 10:15pm
Probably not, but best to check tooth engagement with engineers' blue.
Post #588878 30th Dec 2016 11:14pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
More than likely it will be the same height, but whenever I build a diff always check teeth engagement using engineers Blue and rolling resistance of the pinion itself then with the crownwheel assembly fitted
Kind Regards
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #588890 30th Dec 2016 11:55pm
