Home > Technical > Can you turn off Traction Control on a Puma? |
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 |
Is this for your 2010 XS as in your profile?
30th Dec 2016 12:38pm |
Scrawf Member Since: 24 Jul 2016 Location: Matlock Posts: 25 |
Yep thats right
30th Dec 2016 3:43pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1425 |
searching the forum Ive borrrowed this from this thread - http://www.defender2.net/forum/topic1753.h...ntrol+turn
The fuses for TC/ABS are under the drivers seat they can be pulled and the vehicle will drive fine. We had to do this in Morocco when the front axle exploded on the Utility. On my 2.2 I have a switch although it dose mean I have to look at a stupid amber warning light all the time Last edited by barbel jim on 30th Dec 2016 5:52pm. Edited 1 time in total |
30th Dec 2016 3:58pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2531 |
Barbel jim. I'm confused, you say you have a switch on your 2.2 puma for switching off TC and then puts an amber light on your dash. My understanding was that the switch was for DSC and not TC. On a Land Rover Experience course last year the instructor informed me that you could not disable TC on a Defender, you could only disable DSC. Defender 90XS SW
30th Dec 2016 4:51pm |
Not sure if it turns it off totally, but it becomes very driveable, especially in the wet. I havn't noticed it cutting in, or felt any hesitations as it sorts itself out.
A bit more interesting reading - http://www.defender2.net/forum/topic48551.html?highlight=dsc |
30th Dec 2016 5:46pm |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1865 |
My handbook says the amber light will illuminate and deactivating DSC also reduces the level of ETC intervention (as I now see posted in the previous link ) Rob
1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top (sold) |
30th Dec 2016 5:50pm |
ROBBONTHEROCK Member Since: 23 Jun 2014 Location: Aberdeenshire Posts: 637 |
Sorry, just to confirm.
Pumping the brakes 10 times within ten seconds before starting, will disable the TC. Does this apply to 07MY trucks, with TC and ABS fitted? Cheers Andy |
30th Dec 2016 6:43pm |
Chopperone Member Since: 13 Nov 2016 Location: Derbyshire Posts: 396 |
AND to re arm TC l assume you just switch off - wait - & re start?
Guy[/quote] May your life be like toilet paper ; long & useful. |
2nd Jan 2017 7:35am |
Thanks guys. Tried pumping the brak pedal 10 times with ignition on but not started. TC light came on. Then started and it stayed on. Afterward I just switched off and restarted and the light went out. So now I know!
Thanks for your help! Scrawf |
2nd Jan 2017 8:14am |
