![]() | Home > Technical > Main Fuse Blowing |
![]() Click image to enlarge ![]() Click image to enlarge main fuse 400 to 500 amp work with main battery cable from the battery down to starter motor and Alt make shore you have no faults with starter motor or Alt as well as the cabling ! Glow plug are not wired though this fuse |
Nobby Member Since: 09 Aug 2012 Location: Wiltshire Posts: 444 ![]() ![]() ![]() |
Thanks Dorsetsmith, I thought starter motor, didn't think about the alternator. I was happy the glow plugs were a separate circuit, just the nagging issue with only an issue with the extreme cold. Left me rather confused and almost seeking a cold weather reason, hence the glow plugs on my brain.
PM'd you re fuses. Nobby _______________________________ Puma Defender 90 |
Glow plug wired to link 1 100 amp fuse drivers seat box i believe
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3660 ![]() ![]() ![]() |
am I missing something ?
the drawing shows the starter motor as 300amps hence every now and again a 300amp fuse will blow, if the factory fitted 400 amp fuse this was for a reason, surly if its cold then the voltage is down a bit and the current goes up a bit so a 300amp fuse protecting a 300 amp load will generally blow when its cold and the load goes up and the voltage down? why not go back to the standard factory 400 amp fuse? If that blows then yes you might have a problem DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
PM'd you. _______________________________
Puma Defender 90 |
you have PM
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2295 ![]() ![]() ![]() |
Nobby,
So let me get this straight, you replaced the 500amp fuse that Land Rover fitted with a 300 amp item and now you are wondering why it blows when you put it under pressure starting on a cold morning ? Really ? Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
Mo, for clarity, it was after advice and sound at the time, 2+ years with no issues. Maybe as the Landy gets older and parts age, tolerances change. I only found out tonight that the starter motor draws 300amps. With the cold and now things aging it doesn't now work. Lesson learnt and posted here so others may learn. Don't forget even land rover have made a few mods and fitted lower rated fuses, again something I learnt tonight.
When I set out on my merry journey of Puma ownership, I have sometimes followed advice on various items of change for the better, some of which were checked or discussed with others via this forum. However now I've come to a problem which clearly needs addressing and was a little unsure where to go hence my post. Again others may have gone down the same path, may now taking note and filing it for the time when something similar happens. This forum is about helping, advising and sharing. Nobby _______________________________ Puma Defender 90 |
Interesting nobby, is there a thread you could link to where the 300 amp fuse change is recommended, I should like to try and understand the reasoning behind the recommendation that was made to you ?
PM'd you _______________________________
Puma Defender 90 |
hope it is sorted mate nothing more annoying than a recurring defect DEFENDER 90 TDCI XS,
Hi LR90XS2011,
All is pretty fine now ![]() ![]() ![]() ![]() I may just be the unlucky one whose 300amp fuses and a vehicle getting older couldn't cope. Hopefully anyone else who went this way has an early heads up on potential problems or are having a similar issue now and have an answer. It is the way of the defender, live with it, tinker with it but always learning from it. Nobby _______________________________ Puma Defender 90 |
