Home > Technical > Solar chargers do they work
ibexman
I have to leave my defender laid up for a couple of months I'm thinking solar charger to top up battery , do you have one thoughts please cheers Chris
Post #588126 28th Dec 2016 12:42pm
lohr500
I have a 10W panel wired to a cigar lighter plug which I plug into a permanently live socket in the back of the 110.
It does seem to help hold the battery charge and avoids the chirping from the alarm that I used to get when starting the vehicle after a few weeks of being parked up.
I believe at 10w there is no need for an additional voltage regulator and no risk of over-charging.
There is also a diode in the panel connection block which I gather prevents reverse current flow when the panel is in the dark and not generating any power.
I'm no expert on solar panels so someone else be along with better info.
But for me the 10W panel seems to do the trick.
Post #588130 28th Dec 2016 12:50pm
VeeTee
Netherlands
Yes they do work. I have one permanently fitted on the roofrack, it keeps the batteries (dual system) topped up, and even in winter with short day or clouds I notice the difference.
 Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #588179 28th Dec 2016 4:22pm
roel
Vincent, how much power does that give? Around 300 Watt?
I have a 20 W panel for my D3 and it looks like it just keeps up with the usage off the D3 for longer periods. Roel
2003 90 Td5 (2009-now)
Post #588305 28th Dec 2016 9:12pm
VeeTee
Netherlands
Roel, it is 90 Watts. It keeps up with the fridge power usage when camping if we stay some days at the same place and don't use the alternator. Cheers, Vincent
MySite
Post #588324 28th Dec 2016 9:49pm
NinetyTD4
Wales 2012 Defender 90 Other SW Keswick Green
Trickle charge with a solar panel and solar regulator(!) does a nice job in keeping batteries healthy. I do have a 40Wp panel, which serves on a sailing boat in summer and loosely on the roof of a Defender in winter. Never forget: cars have owner, Landrover have field service personnel.
Post #591074 7th Jan 2017 8:00pm
cobra_mark
United Kingdom 2000 Defender 90 300 Tdi SW Barolo Black
I use a 10w charger direct to the battery as my 90 is only used weekly, does a god job. The bigger panel in the garage has a regulator and keeps my 12v backup battery crisp plus gives me light in the garage, can't fault them. Very Happy
Post #591093 7th Jan 2017 8:34pm
Super7
United Kingdom 1999 Defender 90 Td5 CSW Rutland Red
Possibly a stupid question:
Would anyone know if it is ok to leave one of these small panels permanently connected to the battery or do they need to be disconnnected each time before using the vehicle Question '99 TD5 Defender 90
'52 Series 1 80"
'99 Caterham 7
Post #591269 8th Jan 2017 1:17pm
cobra_mark
I remove mine weekly to use it at weekends, my brother in law has permanently fitted to his camper van with a regulator box and a fuse just pops it in a cubbyhole and drives off.
Post #591272 8th Jan 2017 1:28pm
VeeTee
Netherlands
If you have a small panel you could fit a diode to prevent it discharging the battery at night. Larger panels are always fitted with regulator and can be connected permanently. Cheers, Vincent
MySite
Post #591291 8th Jan 2017 3:19pm
Super7
Thanks, looks like mine has a diode fitted Thumbs Up '99 TD5 Defender 90
'52 Series 1 80"
'99 Caterham 7
Post #591371 8th Jan 2017 7:15pm
