![]() | Home > Technical > Indicator fault |
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 ![]() ![]() |
do you have dash LEDs or lamps.
On early dash boards its a single lamp for left/right indicator (2 green arrows); the system works by discharging in both directions through this lamp. If you put an LED dash bulb in place it sort of links both circuits and they both come on when you indicate. You either need to update the dash where they have separate indicator warning lamps... or replace a couple of your LEDs back to bulbs. (sometimes the side repeaters can be kept as lamps) |
Chris90V8 Member Since: 02 Oct 2016 Location: Suffolk Posts: 714 ![]() ![]() ![]() |
Thank you for your reply....
The Defender is an 87 model, so yes...an early model. Hoping to dedicate a lot of time to this problem tomorrow. Will put your idea in place and see what happens... ....fingers crossed Cheers Chris (Anyone got a newer dash for sale?) ![]() |
http://forum.landrovernet.com/archive/index.php/t-269584.html
...think you have just made my Christmas
![]() ![]() ![]() Chris |
Update...
Searched google and found some valuable info: Ordered a RDX warning light from Bolt-on-Bits (this has an earth wire) and have been assured that this instantly solves the problem with no fuss. (wish this issue was made more aware to owners of early defenders / Land Rover 90's etc when purchasing led indicators, has caused hell in all headaches and time wasting!) ![]() Cost £15 and sent out 1st class - same day ...will update when delivered and installed. Chris |
Just arrived in the post
![]() ![]() Click image to enlarge ...fingers crossed Stand by ![]() |
still standing by - just curious to see if all is ok now
...gonna try tomorrow if I can.
Been side-swiped with the "Lurge"! ![]() |
YIPPEEeeeeeeeeeee
IT WORKS ! ! ! led / diode light fitted... ![]() Click image to enlarge Might get some sleep tonight now, all thou my binnacle mount broke! ![]() (Will be ordering from Raptor Engineering tomorrow) ...gonna be one of those 'Money Pit' projects ![]() Chris |
good to hear;
http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...Sw8w1YBjFq http://www.ebay.co.uk/itm/LANDROVER-DEFEND...Sw44BYaVDR maybe suitable and cheaper than the metal raptor ones |
...going to buy a good quality product
(Fed up buying twice) ![]() Wish they had a emoji with 'cash flying away' ![]() |
