Home > Maintenance & Modifications > Parrot MKI 9200 & iPhone 4 |
carlaac Member Since: 09 Dec 2010 Location: Hampshire Posts: 58 |
Some photos of my install of the Parrot MKI9200
About an hour all up Centre console out, the Parrot kit uses ISO plugs as the 2010MY radio, follow Parrot instructions, very simple. Speedo console out - feed microphone through - remove A pillar trim and mount microphone on sun visor Feed cable through for MKI screen Feed media cables through next to centre air vent fit pro-kit Brodit and pass through cable iPhone 4 holder Results: IMG_6776 by CarlAAC, on Flickr IMG_6775 by CarlAAC, on Flickr IMG_6773 by CarlAAC, on Flickr Last edited by carlaac on 12th Feb 2011 12:09pm. Edited 1 time in total |
12th Feb 2011 12:04pm |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 |
Is there meant to be some photos? Russell
2011MY 110 XS USW Black |
12th Feb 2011 12:08pm |
Russell 2011MY 110 XS USW Black |
12th Feb 2011 1:34pm |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 |
How is the tone quality? I tried an ALPINE Radio with BT connection for iPhone with my old 3G and the 4G, with both meself sounded like a squeezed rabbit and ofer 25mph the vehicle was clearly to understand.
Still searching somthing more comfortable than a wired headset..... WANTED: SII or SIII in max 1.5k |
12th Feb 2011 9:05pm |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 |
I use the bluetooth to conect the iphone and parrot and the ipod seems fine.
12th Feb 2011 9:15pm |
Put it this way, I called SWMBO from the defender whilst I was on the motorway and she was convinced I was still in the office. I'm delighted with it and clearer than the integrated BT on my BMW.
You can stream the iPhone music over BT but the digital direct connection is superb. Amazed how great it makes the standard speakers sound. It might be novelty but used it this week and is a great mod. Next mod is to put HID headlamps on. I put these on my R1200GS adventure and was the best upgrade I have done. Anyone done it to the Landy? I used 50W on the GS and much brighter than the BMW dual xenons. The standard Landy headlamps are laughable!!! My MTB lamps are brighter. |
12th Feb 2011 9:47pm |
ben_j85jty Member Since: 02 Sep 2008 Location: Bicester, Oxfordshire Posts: 491 |
Just a quick question:
Does this enable you to play the music from your Iphone through the stereo? Does the wireless remote allow you to control the music, FF & RW for example? Cheers Ben 2002 Defender 110 DC |
13th Feb 2011 3:16pm |
Ben when plugged in the remote controls the play list etc, not sure on the BT as I just use the screen control on the phone that is mounted on the dash.
If you had asked I could have given a demo today for you. Boy |
13th Feb 2011 5:55pm |
Cheers Boy,
To be honest I have never even thought about a hands free in the Defender, but I am currently looking for a way to add a remote control to my head unit. I have an Apline head unit which I am sure I can get a remote for, bt if I could add an hands free into the mix it may be worth it. Good to see you today Ben 2002 Defender 110 DC |
13th Feb 2011 6:33pm |
The Parrot will let you select the track via artist, album or playlist on the parrot and the remote lets you play/pause and skip tracks forward and backwards.
Also note that the Parrot uses its own amplifier to drive your existing speakers and this volume is controlled via the Parrot so it won't be running through your alpine unit. There are line-out outputs which I guess you could connect directly to the audio-in on an amplifier? |
14th Feb 2011 12:56pm |
