Home > Maintenance & Modifications > Chequer plate wing tops
justinp
Hi Chaps,
I'm thinking about adding black chequer plate the wing tops or my Aintree Green 110 DC, to cover a couple of shallow dents.
A quick google shows there are many manufacturers to choose from, so do you have any recommendations for a good quality wing top chequer plate, or anything I really should avoid?
The alternative is to get the dents pushed out using a PDR company, which I'm also considering.
Thanks - Justin
Post #586905 22nd Dec 2016 8:28am
1978
United Kingdom 2003 Defender 90 Td5 HT Belize Green
Personally, I would definitely opt to have the dents pushed out if they are your only reason for adding the wing tops. Most are riveted on and require the wings to be drilled.
Post #586909 22nd Dec 2016 8:41am
The chequer plate brand to look for is 'Mammoth'. It's reputed to be OEM and is very nice quality.
If you do decide to go for them, make sure you get the foam gaskets to go between them and the wing. Darren
Post #586912 22nd Dec 2016 8:49am
dave18
United Kingdom 1984 Defender 110 300 Tdi CSW Portofino Red
1st off WHY do you want them ?? Do you ever stand or sit on the bonnet or wings, If not then get the dents sorted if you do DEFINATLEY get them fitted
2nd If you do get them make sure they are 3mm
3rd As said above make sure you have a rubber / foam gasket between all items.
Post #586931 22nd Dec 2016 10:08am
RED-DOT
Land Rover dealerships are deducting the cost plus labour plus painting etc from any drilled panel offered for trade in. I wonder why? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #586940 22nd Dec 2016 10:53am
Froglaise
If you want chequer-plate, go for OEM which is 3mm think, 5 ridge and has the foam gasket glued to it. Use nylocks instead of rivnuts is best. Ignore what others think of the look - it's your car to do with how you like.
Post #586941 22nd Dec 2016 11:02am
Froglaise
So that they can pay you less on the PX.
You don't really think they actually remove the plate and have the holes done do you???
No more than webuyanypieceofjunk.com has all the things they chip prices for done before they ship the motors into auction.
Post #586942 22nd Dec 2016 11:04am
RED-DOT
One of our guns has bought a lovely white XS and fitted gloss black CP on the wings and sills and rear corners. Kahn grill, big wheels, leather dash and door panels, black roof with six lights on a roof rack. I reckon he has spent Ģ4,000 on mods which of course he can but i'd rather spend it on skanky Latvian dancing girls after a few wild boar drives. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #586943 22nd Dec 2016 11:14am
tuesdayfox
2013 Defender 110 Puma 2.2 SW Zambezi Silver
get the 3mm and shorter ones
I personally wont get the gasket. waster of money
just use somw silicone
Post #586947 22nd Dec 2016 11:24am
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
I personally don't like CP However if I needed to clamber on the wings to get onto a roof rack or whatever I would fit it.
Post #586949 22nd Dec 2016 11:33am
smb
If you want Top Quality then speak to Kevin or Faye at MUD and ask if he can get you the set from GMB. They also have the feature of a Hydraulic Ram on one side to keep the bonnet open.
Post #586953 22nd Dec 2016 11:44am
pjb
Having scratched my wings CPWT are sitting in the garage as my next job
As for changing the value I think it is very much horses for courses, on a low mileage pristine heritage yes it may make a difference but on my used adventure in 10 years do not think it will make a bean difference Thumbs Up in fact that might be my only "upgrade" that does not alter the value downwards Rolling with laughter 2020 P300 HSE
Post #586979 22nd Dec 2016 1:58pm
justinp
Thanks for the replies chaps.
I'll get the minor dents pushed out in the new year and then make a decision on whether to CP the wing tops. I don't have a roof rack, so there's little need for them other to cover the existing dents.
Post #586991 22nd Dec 2016 3:56pm
Jonno1968
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Orkney Grey
If anyone allows a car dealer to deduct the price of re-doing the wing tops and accepts it then they must have mug stamped on their forehead. My local dealership is full of defenders with wing tops. Personally I like them but I also dislike it when people get carried away with the stuff and put it on every conceivable "vulnerable" surface. It's not just handy for climbing on, let's face it the wing tops are a handy "table" for all sorts and with WT's you don't need to worry. Very Happy
Post #586993 22nd Dec 2016 3:58pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
Chequer plate? Thumbs Up Thumbs Up Thumbs Up
Why do Defenders often have chequer plate on their wing tops? Rolling Eyes
Because they can! Whistle
Very few other vehicles have a useful sized horzontal flat surface on top of their wings. Even G models donīt have enough space to sit or stand on confortably. The CP just provides a stable and robust surface.
Mine came with full set of CP from Nakatanenga fitted by the previous owner. It was that, and the rest of the spec that attracted me to this particular 2.2 90. It looked right, in my humble opinion.
I added the panels surrounding the bonnet hinges last spring, mainly because I liked the look of them.
Almost every time I wash the 90 (which I do by hand), I climb up onto the wing tops, and then onto the bonnet panels in order to clean the top of the cab and the windscreen. I often use the wing tops as a step, seat or to simply as a place to put tools, or whatever Iīm transporting, before loading it into the car.
I wouldnīt want to be without it. It is another feature, that makes the Defender unique.
 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #587010 22nd Dec 2016 5:07pm
