Home > Puma (Tdci) > Bellhousing bolts MT82 - Puma engine |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
The only ones that are different are the 2 that go in the other way (as in engine side, to bellhousing)
The others all go in bellhousing side, and should all be the same length. Can you put any pictures up of what bolts you have? 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
21st Dec 2016 11:40am |
TopQ1967 Member Since: 14 Feb 2012 Location: Veghel Posts: 236 |
Click image to enlarge Thank you. Where do the 100 mm bolts go with the 4 nuts? Click image to enlarge This is the right hand side of the engine. 70 mm seams to short. 100 mm is definitely to long. |
21st Dec 2016 11:51am |
Long bolts are for the cross member...
21st Dec 2016 12:04pm |
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 |
I was just about to say the same Chris
2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
23rd Dec 2016 9:13pm |
