Home > Maintenance & Modifications > Torque adaptor advice
spudfan
Ireland
Has anybody used something like this and if so what are your opinions?
https://www.amazon.co.uk/s/ref=nb_sb_ss_c_...OA6URNN0L9 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #586312 19th Dec 2016 10:32am
DonH2000
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
Looks like a good idea but I would be concerned about how they are calibrated.
My experience of digital tyre pressure guages tells me that they can vary a lot, so how do know if they are accurate enough for the job that you are doing. Cheers Don.
Post #586314 19th Dec 2016 11:01am
agentmulder
Kuwait
Having just done a brake, suspension and transmission overhaul I know was struggling on occasion just to get a standard torque wrench in place.. Solved the bowel problem, working on the consonants...
Post #586398 19th Dec 2016 7:03pm
miker
Same price as a half decent torque wrench, I'd go for the wrench any day!
https://www.amazon.co.uk/s/ref=nb_sb_ss_i_...que+wrench
Post #586465 20th Dec 2016 12:00am
MGCarr
United Kingdom 1997 Defender 90 300 Tdi PU Rioja Red
The first one the page is available from Machine Mart and they claim quite high levels of accuracy for it. I must admit to being tempted by it as a supplement to my conventional torque wrench as there are times that the length of it just will not fit.
Post #586468 20th Dec 2016 12:49am
spudfan
Ireland
Thanks for the replies. I just need something for occasional use, i.e. the oil filter housing on the Puma, sump plug and very occasionally wheel nuts. I did think of the calibration issue but I suppose it will be within reasonable limits on any digital unit. I have borrowed a traditional torque wrench in the past but found it a little cumbersome to use and as I was not used to it and found it hard to set it correctly. I was just curious as to peoples experiences with and opinions on the digital equivalent. Many thanks. 1982 88" 2.25 diesel
Post #586517 20th Dec 2016 11:50am
^^^ Common sense is a lot cheaper than a torque wrench for all those applications, and just as good.
Post #586535 20th Dec 2016 1:18pm
spudfan
Ireland
I've been doing the oil filter housing and sump plug by hand and have not had a problem. Once it's tight and not leaking I leave it. I check them regularly after this and once there are no signs of oil I assume all is as it should be. 1982 88" 2.25 diesel
Post #586540 20th Dec 2016 1:51pm
JustFX
United Kingdom 2000 Defender 110 Td5 CSW Coniston Green
As someone with a bit of knowledge of torque (Calibration Engineer).
To meet the BS standards (BS6789:2003) the tolerances given for torque equipment are either 6% or 4% depending on the type of tool and the range it's being used. Generally <10Nm>10Nm = 4%. The Digital unit above would no doubt come under Type 1 Class C so expect it to be within 4%.
I wouldn't rely on torque equipment as I have seen more bolts stripped due to the "It hasn't gone click yet". It is a tool or aid if you prefer. It's handy to achieve consistent results for example when doing the cylinder head.
It isn't until you actually get to have a go with a torque analyser then you begin to understand how important posture and positioning is when trying to get consistent results within tolerance. Too fast and it will go click and you then it moves a little and you go over then too much angle and you get a low reading. Then there is the point where you apply the force to wrench. Then you have to ask how many times has this bolt been used? Is there oil or grease on the bolt that would affect the torque. Its a rabbit hole that you can get lost down.
BTW the industry uses Norbar (can be found as Halfords Pro), Britool, and Torqeleader. If I was to be buying torque kit then I would look for Norbar Wrenches, A few torque drivers from Torqeleader, and a dial wrench for finding out how tight that bolt was done up. If I wanted to be sad about it I would then also buy a Torque Clock for checking wrenches on before I did anything.
Post #586630 20th Dec 2016 8:10pm
