![]() | Home > Puma (Tdci) > Puma Issues |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
James, it sounds as if they need to be reminded of technical bulletin LTB00254/2010. This is a modification to the wiring harness for the Turbo modulator, I had the exact same fault codes and this was done. See this topic here:
http://www.defender2.net/forum/topic5125.html HTH Brian. |
Bristol 90XS Member Since: 31 Oct 2010 Location: North of Bath Posts: 223 ![]() ![]() |
Hi Brian,
Thanks for the reply. When you had the wiring added did they also replace the MAF and EGR, or did the extra loom resolve these faults also? The car was built November 2010 so I am surprised the newer loom wasnt used as standard on the new builds? Do I go back to the dealer with codes and ask them to look at the TSB? Also do you know if there is any damage to the existing loom caused by the vibrations/stretching? Sorry for all the questions! Thanks again, James |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2458 ![]() ![]() ![]() |
I find quite unbelievable a 2011 landy has those issues. After 4 years still with such cr++py failures? Is quality control managed by a parrot? Puma 110" SW
They replaced the Turbo modulator loom and EGR,MAF and one week later I still have no DTC's showing
![]() ![]() Pm me your email address and I'll send you a couple of relevant bulletins applicable your fault codes ![]() Brian. |
Great - really appreciate you help!
So it looks like the fix is to replace all 3? Seems unlikely the maf, EGR and turbo loom are all faulty at the same time though? Do you think it is just one that creates the other 2? I'll pm you my email - this dealer has had the car nor for two weeks of our 8 week ownership so may try another... Thanks again much appreciated!! James |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5080 ![]() ![]() ![]() |
I was of a similar mindset...so I replaced just the maf
Could see no obvious reason why the loom needed a change...I've changed maf, but I forgot to clear the log..so I'm going to monitor it...next will be the egr if required. Mike |
