Home > Off Topic > Topside beef cooking ideas
excossack
Got a 2.5kg topside beef joint for xmas day after suggestions on best way to cook so the meat is not like leather.
Just done a 500g silverside joint in the oven for time suggested - 30mins but ran over a little and had 10min resting time.
Meat was pink but tough! - pan fried first on all sides to seal and then in the oven, started on 220c then turned it down 180c on a middle shelf covered with tinfoil and added 100ml red wine.
So need to improve for xmas day.
Have been thinking of using the slow cooker instead of the oven. Open to thoughts from cooks, butchers, experts etc. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #586156 18th Dec 2016 7:02pm
gabe3105
Think both silverside and topside from supermarkets are cheap cuts and need low and slow cooking to avoid being like leather. I would suggest sticking it in the slow cooker on low for about 7 hours and seeing what it is like. No liquid in there, just the beef.
Regards
Heston Blumenthal
Post #586157 18th Dec 2016 7:08pm
Riverboy
2014 Defender 90 Puma 2.2 SW Corris Grey
Go to a good butcher and never buy meat from a supermarket. He'll also tell you how to cook it to perfection. Thumbs Up
Post #586159 18th Dec 2016 7:18pm
jst
for those joints from the butchers i use bottom over/slow cooker approach after sealing first. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #586177 18th Dec 2016 8:12pm
LR90XS2011
I have success by cooking in a casserole with the lid on with the joint sat in about 1 cm of water, cook like this, lots of recipes like this, look up pot roast the beef will melt in your mouth
good luck DEFENDER 90 TDCI XS,
Post #586190 18th Dec 2016 8:36pm
bob neville
For topside you should let it rest for longer than 10 minutes.
20 to 30 minutes is the normal resting time for this cut.
2013 Defender 90 CSW - sold
Post #586231 18th Dec 2016 9:36pm
excossack
Thanks for the replies people. Plenty to go.
@Bob
Rest the meat on worktop covered in tinfoil, or elsewhere? 1999 Defender TD5 110
Regards
John M0VAZ
Post #586235 18th Dec 2016 9:50pm
bob neville
I let mine rest on a chopping board uncovered.
When you remove the joint from the oven the core temperature continues to rise for quite a long time so the long resting time allows the internal temperature to stabilise and then lets the fibres relax.
Guess whose mum and sister were professional chefs Smile
Bob
PS If you have not got/ordered the meat yet then go to a butcher to get it, supermarket beef is hit and miss for quality. 2015 Jaguar XE240 R Sport - goes like ....... !!
Post #586254 18th Dec 2016 10:34pm
Darcy Fairfax
England 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
Try this link from the Ginger Pig guys. They're a pretty good butchers.
https://www.thegingerpig.co.uk/meat/beef/
Cheers,
D
Post #586266 18th Dec 2016 11:18pm
excossack
I have purchased the meat already. 21 days matured according to the label.
Time for a bit more reading before Christmas day. 1999 Defender TD5 110
Regards
John M0VAZ
Post #586445 19th Dec 2016 10:05pm
Iggle piggle
United Kingdom 1989 Defender 90 V8 Petrol ST Alpine White
I can highly recommend this app, http://www.time-to-roast.com/
For me a quality joint of Topside at room temp, & a red hot oven to start
I try & use our local butcher for Beef but he can get a bit expensive!
If it has to be a supermarket in my opinion Morrison's is the best for Beef & Lamb, as far as I am aware they are the only Supermarket that sources Beef & Lamb direct from the farm (they even have there own fleet of live stock trucks to transport to there own abattoir's)
http://www.morrisons-farming.com/
Post #586500 20th Dec 2016 10:01am
bob neville
As we have not heard from you John I take it the outcome was not good ???
Post #588293 28th Dec 2016 8:44pm
LR90XS2011
LOL DEFENDER 90 TDCI XS,
Post #588295 28th Dec 2016 8:50pm
excossack
Thanks for the reminder!
Started off with 2.5kg of beef. Chopped in half ish (1.3 KG into casserole dish for the over on a 150c middle of oven for 3 and a bit hours and then some resting time).
Beef & ale stock flavour thingy and some boiling water for the stock with some red wine,
Marinated over night in Garlic and some marinade from Sainsbury's
Added some chopped celery herbs into the pot and cooked away.
Other chunk of meat (1.2kg)in the slow cooker with a stock pot and a bit more red wine, chopped celery, carrots and herbs. High for 4hrs and then low for 2hrs ( I think it was)
Took both out and left to relax while the spuds and Yorkshire puds went on.
Carving the oven cooked meat was easier and it stayed together.
Carving the slow cooker cooked meat this ended up like pulled Pork
To me oven meat was dry and slow cooked meat a bit better. Not a huge success but edible. 1999 Defender TD5 110
Regards
John M0VAZ
Post #588325 28th Dec 2016 9:52pm
bob neville
From what you say I reckon that is not bad at all Thumbs Up
The one thing I will never do at Christmas is roast beef, there are two many variables even with a trusted local butcher nearby to supply the meat.
Well done !
Post #588330 28th Dec 2016 10:17pm
