![]() | Home > Puma (Tdci) > Tdci running rough and cutting out. |
Are all of your glow plugs all working
![]() ![]() Click image to enlarge ![]() Click image to enlarge |
If the engine started may be the glow plugs are OK,
IMHO a little be of Diesel paraffine due to the below zero T°, Are you using artic fuel (Diesel with additives for low temps). Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
The only reason i thinking glow plugs is that my pickup had same problem and it turnout to be two glow plugs not working replaced them and next cold start -12c not problem
mobilesawmiller Member Since: 03 Mar 2013 Location: Co,Tyrone Posts: 100 ![]() ![]() |
Thanks for the information lads. I will look at the glow plugs and my diesel. Have a good Christmas.
