![]() | Home > In Car Electronics > Dash bulbs |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20595 ![]() ![]() |
What engine / year? Play Stupid Games, Win Stupid Prizes.
Big Brother is Watching. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5230 ![]() ![]() |
One landy is a 1994 the other is a 1997/1998, Basically 200 tdi and a 300 tdi
if you can not find right ones i have used this below
jr1104 Member Since: 05 May 2016 Location: England Posts: 78 ![]() ![]() ![]() |
Just fitted a set of LED bulbs from Fourby.co.uk to my 300TDI. Has definitely helped with the brightness, and the blue colour is more legible than the dull green.
From the way way the light shines around the dials though, I'm not sure it'll ever be as bright as a modern car. All you can really do is make the edges of the dials get brighter! |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
Not sure if you can replace the clock bulb, normally sealed? I put the blue LEDs in the other dials and it is an improvement. Jeff
Ex 1968 Series 2A Ex 90 TD5 Ex D3 Ex D4 |
I replaced the clock bulb when doing mine. It's a different type of bulb, but was as easy to change as the rest of them.
