![]() | Home > Maintenance & Modifications > fitting sump/steering guard |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 ![]() |
Just got one, any have a fitting guide?
thanks Pom |
ok
![]() Pom |
When you match the brackets up you will see what bolts you have to undo there are only 4
![]() Last edited by fekete on 11th Feb 2011 5:43pm. Edited 1 time in total |
well i got 3 big bolts with the guard, is there a 4th already on the chassis somewhere ?
Pom |
18stone Member Since: 16 Dec 2010 Location: Mid Essex Posts: 137 ![]() ![]() ![]() |
From my TD5 days the 4th bolt was through the tie-down loop/chassis rail?? D300 HSE 110
Yes. just put it together loosely and offer it up and you ll see the bolt that's already there. its easier to put it together than put the side plates on then put on the base plate, because if you dont put the base plate on first its a ![]() |
Martin90 Member Since: 12 Feb 2010 Location: Abu Dhabi Posts: 19 ![]() ![]() ![]() |
Pom,
The bolt that you re-use is the chassis bracket for the panhard rod. I put the two side brackets on first and then lifted the plate up but as stated was a bit tricky, but doable. If you do it this way, do not tighten the brackets to the chassis until you get the plate on as you need a bit of "wiggle" to get the holes in the plate lined up! Martin 1989 90 - Truck cab, Mazda 35 SLTi engine 2009 90 - Station Wagon |
Dependent on the steering guard you may have to undo the steering dampner and thread one side piece over it. If there is a 75-100mm hole in one side that is what you need to do
HTH Brendan |
uh oh, first problem. There is a doo dah (i dont do mechanicing)in the way.
Here is where it needs to go, the doo dah is up tight against the chassis no way to slide the clamp behind it ? ![]() Click image to enlarge Pom |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5871 ![]() ![]() |
I think the brack for the guard goes on the inside of the chassis, not the out side where the "Doo Dah" is
Andy |
As shown in this aquired photo
http://www.defender2.co.uk/gallery/albums/....06.15.jpg Andy |
leaving it for the grease monkey. i was guessing it wouldn't be a straight forward job!!
Pom |
It is simple I just think you are putting the wrong side bracket on the outside of the chassis instead of the inside. You just need to undo the bolt through the "doo dah" slip on the guard bracket and do bolt back up. (After you have removed tie down eyes from chassis)
But I am sensing you have had enough ![]() Andy |
yeah you could be right!
