Home > In Car Electronics > Tail Stop light - one positive and two negative leads |
Giby_off Member Since: 05 Apr 2015 Location: Sofia Posts: 63 |
In addition, when you turn tail light on there is 12V between the ground and one of the driving wire and also 12V between the same driving wire and the other driving wire which means that in this case both wires are connected to the ground. Voltage between both negative wires are 0. I was not able to measure the signal with the break pedal on because I was alone.
In the above mentioned scenario LED light did not came on. I did some test with battery and I managed to reproduce it at home. if you have negative connection to the ground and one of the driving leads and positive to the other the LED will not come up. If you disconnect the the ground from the driving lead it comes up. I tested with two different LEDs and both working in the same way, so the question which remains is do you know which LEDs are compatible with Defender setup? |
11th Dec 2016 5:14pm |
Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230 |
I use LED 2 pin globes in the rear of mine without any issues.
There is one earth that goes to the out side of the globe holder. The brake and tail lights conect to the terminals at the bottom of the socket and both are positive feed. The globe should have 2 staggered pins on the side so it only fits one way to ensure the correct conections to the terminals. Depending on the method used to test earth you may have got a circuit via the other globes. Compare the pins on your replacement globes are the same(stagered). Also check the 2 contacts are in a similar location in relation to the location pins. To me it sounds like the replacement globes are not correct. Cheers, Kyle. Cheers, Kyle. |
11th Dec 2016 9:10pm |
My replacements looks like this one...
https://www.superbrightleds.com/moreinfo/t...ofit/2625/ Cheers, Kyle. |
11th Dec 2016 9:23pm |
WhAT i am trying to explain is that when you are with light on one of the pins receives +12, the ground receives ground which is OK but the other PIN also receives ground and in this configuration most of the dual LEDs I've tested doe not work.
If you remove the ground from the second PIN the LED immediately lights up. I will try to find LEDs like those proposed by Alien or will try to build two by myself. Most probably many other people are hitting the same problem. |
12th Dec 2016 3:15pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20583 |
It should be Earth, tail, brake.
Did you have tail and brake on the old lights? Sounds like it would either be tail only or brake only with that config. Use an inditpenant earthing point if you haven't already to isolate the earth of the plugs. You may as well check continuity whilst you are at it too. Make sure everything is switched off. Are you sure that it hasn't been required wrongly or polarity switched? Could be that the earth is live and the two live feeds and now earth instead. (Switched polarity) LED's are polarity sensitive too, so that is also worth bearing in mind. But I definitely remember on mine it was - Earth, tail +, brake+ KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
12th Dec 2016 3:39pm |
The main problem is that stop wire is grounded when stop pedal is not pressed and has 12 V when pressed.
When bulb receives ground on one of the PINs it (except its ground) it does not work. I tested the LED connected directly from the battery and everything is OK. Original bulb has stop and tail light. I guess if I have bulb with 20 leds and 5 are turned on while lights are on and 20 on when stop is on then everything will be OK. Those leds which are on the market lower light intensity. |
12th Dec 2016 6:23pm |
