Home > Td5 > Leaky Radiator |
bogwert Member Since: 02 Sep 2016 Location: Dundee Posts: 194 |
Walked up to the parked 90 the other day I noticed its been marking its territory (awwwww).
Having just driven 200 miles it seems to have leaked out and around the radiator... area (it was quite dark). It was quite a cold (-3) road trip from Dundee to the lakes so i thinking the cold air might have helped keep things cool. Shame Scotland is renown for it long hot summers! After checking the expansion tank its definitely dropped but not considerably. Doesn't seem to leak when its cold, so I'm thinking it may be down to pressure. Other than ripping it all apart any pointers to fault finding? What pressure does the radiator system work at normally (when its all hot and running)? Worth getting a pressure gauge or a pump to test it? Chris 2014 Discovery 4 TDV6 HSE 2003 Defender 90 TD5 CSW |
7th Dec 2016 4:10pm |
below 1.4 bar or 20 PSI witch is open pressure for the cap
7th Dec 2016 4:18pm |
10th Dec 2016 2:58pm |
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 531 |
Fellow dundonian
Mine was the complete opposite. Only leaked when cold, could see it tracking down the road fins, onto the crossmember and dripping onto the ground Oddly, it never got close to overheating either Cheap enough to repair though |
10th Dec 2016 5:54pm |
Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230 |
Have a look for stains at the fuel cooler before starting it up.
The O rings only leak when it's cold and coolant could be migrating down the hose towards the radiator when stationary. Cheers, Kyle. Cheers, Kyle. |
10th Dec 2016 11:12pm |
So drove it out to the back of Dundee (15 mile trip). Bone dry when I arrived, left it to cool and the drips appeared.
Might be on the same lines at Mikey's. I'll bring it round in the new year Mikey! Alien, seems dry before starting it up but will keep an eye on it! Chris 2014 Discovery 4 TDV6 HSE 2003 Defender 90 TD5 CSW |
11th Dec 2016 11:47am |
I look forward to it
11th Dec 2016 10:05pm |
Due to lack of time and daylight in the week, ended up taking it to Disco_Mikey at MMP, Dundee.
Turns out the radiator was , to say the least. what looked like a few missing fins, behind was a ruined radiator bowed and leaky! Thanks to Mike though who had it diagnosed and turned around with a new shiny one within 2 days! Excellent work, thanks mate! Click image to enlarge Chris 2014 Discovery 4 TDV6 HSE 2003 Defender 90 TD5 CSW |
25th Jan 2017 9:45am |
Baz8046 Member Since: 08 Feb 2016 Location: Chatham Posts: 81 |
Looks very similar to mine which I changed before Christmas.
All the fins had corroded at the bottom and the lower edge was bowed. Mine wasn't leaking but it wouldn't have been long. Click image to enlarge Defender Td5 Commercial 2002 Range Rover L322 TDV8 Westminster 2012 Discovery 4 SDV6 Landmark 2016 |
25th Jan 2017 11:41pm |
