Home > My Defender > My 90 having a full rebuild
Page 3 of 16 <123 4 ... 141516>
MetalMatt
United Kingdom 1989 Defender 90 300 Tdi HT Baltic Blue
Tonight i will be bringing the rolling chassis back to my container so i can start to fit the body on, as i now have the gearbox in and all working, and got the wiring in place. So tomorrow it will be all systems go to get the 90 back on the road ASAP. Very Happy Very Happy Very Happy Very Happy
Post #563565 13th Sep 2016 8:18am
MetalMatt
Well shes all loaded up and ready to come to have the next stage of the rebuild Very Happy Very Happy put the rear tub on and put the shocks on and diff guards, then roll on the weekend Thumbs Up
Post #563830 14th Sep 2016 9:55am
L110CDL
Looking good Very Happy Hope you have a good weekend with the build Thumbs Up Clayton.
Keeper.
Post #563986 14th Sep 2016 8:48pm
MetalMatt
Well this weekend went mostly well. in terms of getting the body on. Just a few questions. 1) how do you line up the doors and move the bulkhead so its in the correct position.
But here we have some photos of the build Very Happy
Post #565073 19th Sep 2016 12:46pm
Retroanaconda
1. Mount the rear tub by the rear crossmember tab bolts, leave the front attachment points loose for now.
2. Mount the bulkhead loosely and attach the door to it, leaving a straight and even gap between door and bulkhead pillar of around 5-7mm. Space the bulkhead feet from the outriggers using washers as appropriate to give a similar gap at the other end of the door (this may require adjusting later).
3. Run a piece of string from the bulkhead to the back of the rear tub, in the 'valley' of the barrel-side part of the body - i.e. just below the upper door hinge. Pull it tight both ends.
4. Adjust the rake of the bulkhead (using the slotted forward mounting brackets that go from the footwells to the chassis) and the vertical position of the front of the rear tub to achieve a straight line all the way down the barrel side of the vehicle. This can take some doing! Tighten the fixings.
5.Re-assess the door gap, ensure that the gap at the front and rear of the door are more or less equal and straight (parallel). Obviously if you need to move the bulkhead forward/back you will need to ensure that the rake angle is maintained also.
7. Repeat for other side.
Post #565100 19th Sep 2016 3:49pm
MetalMatt
Thank you for That, Seems to be a pretty straight forward following those steps Very Happy will give it ago on the weekend.
when you say space the bulkhead using washers. Is that putting washers inbetween the outrigger and bulkhead? if so how do i remover the bolt and not let the bulkhead drop. Would using a jack taking the weight be the best solution?
cheers
Post #565318 20th Sep 2016 9:49am
Retroanaconda
Yes.
Post #565615 21st Sep 2016 6:44pm
MetalMatt
Well its been quiet some time since i have worked on the 90, about 1.5month. But i have got the doors pretty much lined up, the roof is in position it just needs fastening down now. just got to put the seat rails in and festend those up between the bulkhead and tub. Very Happy
i have also just purchased a TD5 seatbox. My question is as the fuel tank is under the drivers seat. do i need to cut the base out of the seatbox on the drivers side? if so how have people done this??
Post #583098 6th Dec 2016 4:28pm
MetalMatt
Well this was annoying and unsuspected. Whilst bolting the seatbelt mount to the outrigger it sort of crumbled and fell out. so purchased the repair sections from YRM and spent a whole day fixing the passenger side up. looked over the drivers side and it seems fairly solid but for safety i decided to put the repair pannels on that side as well. Then the sill rails went in and sat the seat box on and its starting to look more like an interior again Thumbs Up Thumbs Up
Next is fitting the fuel tank, figure out where to cut the base of the seat box out and fit thast in place, put the floor panels in and seats on the seat box, then its time to do all the pipe work etc on the engine, and then all the wiring for the lights.... Not much left to do!!!!
Post #586320 19th Dec 2016 11:16am
Procta
looking good there! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #591344 8th Jan 2017 5:59pm
MetalMatt
Cheers Thumbs Up , Slowly getting there and i can start to drive the old girl again Very Happy Very Happy
Post #591777 10th Jan 2017 9:50am
MetalMatt
been a productive weekend, got the fuel tank in, managed to fit the seat box in once i had removed the storage box from the drivers side so it would fit over the fuel tank, made up the seat box lid kits and place the floor panels in as time ran out to stop play Laughing
Starting to look more like a 90 again and not a pile of parts Very Happy
Next step is to get the seats, cubby box and seat belts in, gearbox tunnel. then thats pretty much the "middle section" of the 90 done. and time to start the pipe work and wings and cooling etc on the "front Section"
Post #595534 23rd Jan 2017 10:06am
L110CDL
Nearly finished another section there Thumbs Up looking good with the black and blue combo Whistle Clayton.
Keeper.
Post #595707 23rd Jan 2017 8:17pm
We'll done, nearly there. Keep at it.
Post #595713 23rd Jan 2017 8:28pm
MetalMatt
Cheers, got black steel modular wheels with mud tyres on as well but i cant fit those as it wont fit in the container where its kept lol Laughing
Post #595851 24th Jan 2017 11:01am
