Home > Td5 > Which steering box do I have? 2001 TD5 90 |
MC84 Member Since: 22 May 2016 Location: Near Bristol Posts: 360 |
Hi, my steering box seems to be weeping at the input seal. How easy is it to replace just that seal? I need to know which type I have, 3,4 or 6 bolt before I order a bag of bits. Which bolts are we counting?
Are there any links to "how to replace my steering box seals"? Mike Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
4th Dec 2016 4:03pm |
if look at top steering box see how meany fixing bolts for the top flange 3 or 4, 6
have look at the link below http://www.allbrit.de/UNI.cfm?PAGE=756724&SPRACHE=EN |
4th Dec 2016 4:20pm |
Hi, looking from the top, the top cover has 4 bolts. It also (perhaps irrelevantly) has 4 fixing bots to the chassis rail.
How easy would it be to change just the input seal? There seems to be a shield over the oil seal? In-situ? Mike Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
4th Dec 2016 4:31pm |
Top cover has 4 bolts ok that's the type you have
4th Dec 2016 4:43pm |
Thanks for the help dorsetsmith Mike
4th Dec 2016 4:47pm |
workshop- manual showing steering box overhaul
http://www.landroverweb.com/Pdf-files/Manu...nual-4.pdf also http://www.rangerovers.net/repairdetails/s...ngbox.html |
4th Dec 2016 6:51pm |
Excellent, many thanks Mike
4th Dec 2016 7:21pm |
