Page 962 of 1378 <123 ... 961962963 ... 137613771378>
Augustus
2014 Defender 110 Puma 2.2 SW Corris Grey
You're so spot on!
('Cept it's her pride and joy 😕 )
Post #582482 3rd Dec 2016 7:37pm
Landie
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Checked my chassis today after a thorough clean inside rails with a hose and air compressor. Close inspection found rust spots that I could push through with a screw driver. Only the drivers side affected due I think to the wiring harness inside. Treated inside with Penetrol and going to decide weather to weld bits over the rusted sections. Fitted a gas strut to the back door. Bloody brilliant.
Post #582560 4th Dec 2016 2:21am
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
Wild Card 90 wrote:
Took the wheels off the other week, and recoated all the chassis and suspension parts, where neccessary, in preparation for winter.
Then coated the brake callipers in RAL 1018 Zinc yellow to match the Koni shock, and gave the underside a general eye over for any signs of leaks. Discovered that the rear diff breather pipe was crushed and damaged (probably during the installation of the side exit tailpipe, over a year ago). This had caused the diff to spew oil through the pinion seal. Front discs were worn out, too. On the list for the 80000 km service.
Service completed including fitting the Ashcroft shaft kit (telltale rust visible in the gearbox opening), and winter tyres fitted. The drive back from the dealership felt so smooth and quiet, which I wanted to attribute to the shaft replacement, but then remembered the soft and smooth winter tyres, which always feel luxurious, after a season of knobbly MTīs.
I like your job !
Thumbs Up Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #582569 4th Dec 2016 7:20am
Took the 110 down to Dorset to collect a set of wolfs with MTRs and my bare SVX alloys
Then off to Bath to collect twin wall chimney for the new log burner
Back home, then a snow foam, wash and dry ... back in the garage
(Anyone else use a leaf blower to dry their truck?)
Post #582586 4th Dec 2016 8:48am
Leaky 110
Scotland 2007 Defender 110 Puma 2.4 XS CSW Zermatt Silver
Made an unscheduled pit stop at the side of the road to reattach my snorkel which worked it's way loose.
"What's that knocking sound"........."arrrrrrgh"
Post #582725 4th Dec 2016 8:34pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Can't say I have. But used it many a time to get a damp bonfire raging Twisted Evil
Post #582729 4th Dec 2016 8:46pm
Liam
Netherlands
Used the leaf blower today before installing a Wipac led kit. Had to look hard for the relay; it was located behind the instrument cluster - not behind the fuse panel
Post #582731 4th Dec 2016 8:55pm
This:-
04/12/2016 at 08:13. 2007 TDCi.
Post #582810 5th Dec 2016 9:19am
familymad
How many clutches to arrive at 200k? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #582813 5th Dec 2016 9:36am
Driven plate number four is currently in the vehicle, and will be replaced as soon as I get the chance.
I work on the theory that every 50k miles the box comes out for the intermediate shaft to be checked and greased (that is still the original, by the way), and the clutch to be replaced.
Post #582815 5th Dec 2016 9:39am
Procta
topped up screen wash, and had a good look over.
Post #582857 5th Dec 2016 1:30pm
CarMan
Strata Florida Very Happy Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top (sold)
Post #582962 5th Dec 2016 9:41pm
How was it CarMan?
I think it's probably 10 years since I did it?
Post #582977 5th Dec 2016 10:37pm
CarMan
Fantastic in beautiful sunshine though foggy locally. Never done it before, but will post some pics hopefully soon and hope to go back to do it the other way. Apparently more rocky than it used to be, water was quite low in places, though still came in the footwells and made interesting by the ice.
Post #583009 6th Dec 2016 7:47am
L110CDL
^ ^ ^ Its great when you do the SF for the first time Whistle 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #583331 7th Dec 2016 9:03pm
