Home > Puma (Tdci) > Friction plates generations for Puma
Page 2 of 3 <123>
jwb
United States
It looks like LR048731 is still the latest part number for the clutch kit, can someone clarify if AP Driveline kit (the OEM producer?) is the same as that branded by Land Rover (except for the �75 markup)?
For example, see the long list of options from the below vendor (or any vendor of your choice).
https://www.lrdirect.com/LR048731-Kit-Clutch-Repair/
Also, I inquired about the upgraded version from Sachs (supposedly producer of the AB clutch), but was told they are no longer producing it for the Puma.
Post #521106 5th Apr 2016 12:06pm
hornet
There is an AISIN product (KE-LR04R) available. As they produce for Toyota, there might be a chance to get a good quality for a reasonable price. Saw it for roundabout � 300,-- Thats ~ twice as much as for the AP-aquivalent.
There exists an uprated clutch as well, introduced for the "stronger" autobiography LR-Models (LR072972). Very expensive. Reasonable price from B*****rt, but they are known for their quality...
Post #522198 8th Apr 2016 12:35pm
YorkJ
United Kingdom 2007 Defender 90 Puma 2.4 HT Zambezi Silver
I can confirm that the latest part number gives a clutch that actually works this time, and doesn't seem to be made from chocolate. as with previous versions.
As with a recent replacement of Clutch, Slave cylinder, Pipes and Master Cylinder 4000 miles ago.
and shaft the sodding thing still rattles like an old one thats about to fall out of its arse.
it would appear that its just a made do an live with situation as I cannot see an issue as to why it is producing the idle rattle it is.
Landrover so noises are to be expected i guess.
Post #531186 13th May 2016 7:46am
Stickman
United Kingdom 2007 Defender 110 Puma 2.4 SW Keswick Green
Hi all,
I have just joined the forum, but have gleamed much helpful advise in the past as a 'guest', so many thanks to all who contribute.
I was reading this thread bout tdci clutch revisions, since I have recently purchased a 2007 tcdi 110 station wagon with 43.5K miles and there is an audible noise / rattle when the vehicle is idling. The noise disappears when the clutch is depressed and there is quite an abrupt rattle when the engine is switched off and everything comes to a halt. The previous owner was completely transparent about this development, which he claims has developed over the last few months - he told me that when he took the vehicle to the garage they suggested that the noise was probably due to compressed / damaged clutch springs.
I am interested to know if the above symptoms support the well documented 'dodgy clutch' scenario.
I was also hoping to get a handle on whether this problem was likely to get rapidly worse or whether I have a reasonable period of time in which to deal with it? - We are planning to drive down through Spain to Portugal later in the summer and I will struggle to find time to get it sorted between now and then.
Many thanks in advance for any feedback / advice.
Post #541739 20th Jun 2016 10:54am
TopQ1967
Netherlands 2012 Defender 130 Puma 2.2 HCPU Buckingham Blue
Face the same problem. Looking at LR048731 gives a Varity of brands (LR, AP, Sachs...). Prices vary too..
Which one to go for?
Post #581045 28th Nov 2016 10:49am
MK
Mine is showing some noise symptoms (like bells). There are also LUK and Quinton Hazell brands as well. Somewhere I read AP Driveline are not that good.
There is the HD alternative but the original LR is very, very expensive. Puma 110" SW
Post #581048 28th Nov 2016 10:56am
Strang3rr
Russia 2008 Defender 90 Puma 2.4 HT Santorini Black
Hi everyone. In Russia some def owners install whole kit from ford transit to avoid rattle sound...
The kit number is 835060 VALEO.
That owners says that no rattle sound and clutch pedal is easier...
Don't anyone done this? Any comments?
Post #582371 3rd Dec 2016 12:27pm
MK
Perhaps the pre-damper springs are internal. Puma 110" SW
Post #582425 3rd Dec 2016 5:14pm
TopQ1967
How lose are the springs in a new clutch plate?
There was a notifyable rattle in my clutch plate that disappeared when engaged the clutch pedal.
Ordered a new clutch plate. But springs are lose too.
I filmed it. But cannot send a film to the site.
Thanks for your help.
Q.
Post #586580 20th Dec 2016 6:19pm
MK
It is normal (as stated on some of the bulletins). Puma 110" SW
Post #586679 21st Dec 2016 2:29am
MK
Cross reference numbers of LR Puma clutch kits (other than AP)
AISIN KE-LR04R Clutch Kit
BLUE PRINT ADJ133008 Clutch Kit
BORG & BECK HK2394 Clutch Kit
COMLINE ECK270 Clutch Kit
EXEDY RVS2022 Clutch Kit
KAWE 962718 Clutch Kit
LuK 626 3098 09 Clutch Kit
MDR MCK-1LR1 Clutch Kit
NATIONAL CK10059 Clutch Kit
OPTIMAL CS0872 Clutch Kit
SACHS 3000951539 Clutch Kit
QUINTON HAZZEL QKT2925AF Clutch Kit Puma 110" SW
Post #586705 21st Dec 2016 11:14am
OldDD
Isle Of Man 2012 Defender 90 Puma 2.2 HT Orkney Grey
I would be very interested to hear from anyone who has done this conversion!
Post #598297 1st Feb 2017 5:50pm
Simon.pl
Poland 2007 Defender 110 Puma 2.4 HT Keswick Green
Same here. Looking for a replacement at the moment and have NO IDEA which route should I take.
There is a Britpart kit that comes with an uprated plate & cover - no LR072972 - for 260GBP, and a "simple" kit LR048731 for half that money. You can also find Clutch Kit 2-part for LAND ROVER DEFENDER 2.4 07-on TD4 244DT Sachs Genuine LD on fleebay for 200GBP, and Ashcroft sells the AP for half of that..
Anyone have any clue what is the best route?
I would add I plan to do the remap one day so stronger clutch would be a desired option BUT the softer version of 835060 VALEO (as it was said here) is tempting too, so.. HELP Big Cry
Thumbs Up
Post #599697 6th Feb 2017 9:51pm
devnull
 2011 Defender 110 Puma 2.4 SW Stornoway Grey
There is also a set that LR put into the 150hp versions of last release of Defender, I remember dgardel mentioned exact part number from LR and Ford but can't find it right now.
Post #600886 11th Feb 2017 9:45am
MK
Part number LR072972 Puma 110" SW
Post #601093 12th Feb 2017 1:46am
Page 2 of 3 <123>
