Home > Puma (Tdci) > HELP please - Performance issue.... |
Butchers Boy Member Since: 10 Jan 2016 Location: Essex Posts: 426 |
Sounds like turbo hose has split?
OR My VWT5 dose this in cold weather if I switch it off and restart it clears it... Something to do with the ECU going in to 'limp mod' Has she tried turning the engine off and re-starting?? 2010 Defender 90 HT The longer I live..... The better I was! |
28th Nov 2016 6:23pm |
lmanton Member Since: 20 Jul 2014 Location: Shropshire & London Posts: 50 |
Thanks, I will try and call her now to check..
28th Nov 2016 6:34pm |
Thank you! Quite amazing but yes once she restarted the engine the defender is back to normal ! Quite bizarre as it has been in colder climates before. I really appreciate the advice. Thanks again, I would never had thought it would just clear like that.... |
28th Nov 2016 8:34pm |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3525 |
Sounds like Butchers Boy could get a job in every IT help desk I have ever contacted; 'Have you tried re-booting it Sir?'
28th Nov 2016 8:37pm |
