![]() | Home > Maintenance & Modifications > Adding Alpine & Rear Quarter Windows? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
Correct, but the location and size of the holes is critical. I am told that the Alpine lights are especially difficult to get right, and are especially difficult to fit.
The rear quarter windows, assuming you mean the two little windows on either side of the rear door, seriously compromise the security of the vehicle, since they can be removed without tools in under 5 seconds. I would not fit them to one of my vehicles unless I also fitted some kind of security grille. |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1875 ![]() ![]() |
I wanted to do just that.
Urban have advised they will not do either, which I find odd as I am sure they have in the past. Anyway, my local independant has just done it on a brand new 90HT apparently without drama, but I understand you have to use older type alpine fittings as the new ones are for roofs with a preformed shape for the alpine windows. Being a coward I think I have pretty much canned the idea ![]() 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top (sold) |
Mr Fox Member Since: 10 Sep 2011 Location: green & pleasant land Posts: 1038 ![]() ![]() ![]() |
Cheers Blackwolf, I assumed that would be the case.
CarMan, I've got faith in my local window shop but I know I'm taking a risk. If I end up with one without windows, I'm going to try living with it but I wanted to know if there was an easy solution if I found light and visibility an issue. ![]() |
Butchers Boy Member Since: 10 Jan 2016 Location: Essex Posts: 426 ![]() ![]() ![]() |
Try these ![]() https://www.landroverdefendersecurity.com/...ndows-only 2010 Defender 90 HT The longer I live..... The better I was! |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6126 ![]() ![]() ![]() |
I fitted alpines to an old plain hardtop 90 I had some years back.
Just a case of measuring off of another roof that had the holes in it, then cutting. Use that special tool to get the rubber "inner" bit in place, along with some washing up liquid for lube. Easy job. |
LinDens90XS Member Since: 24 Feb 2012 Location: Merseyside Posts: 83 ![]() ![]() |
I fitted alpine's to my old 90td and also side windows. Just make sure you measure more than once before cutting, take your time, I used a jig saw but if you have access to a nibler it will be a lot easier. The hardest job was fitting the thin insert without the proper tool, especially as I fitted it to the inside of the vehicle as a deterrent to those who wish to gain acces. Take your time and be patient. HTH. Regards
Dennis. |
Paulv8 Member Since: 09 Jun 2013 Location: Milton Keynes Posts: 618 ![]() ![]() |
Yup. I have fitted them all. Easy really, but the alpine glass is hard to install. V8 90...WIP
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
Speak to Dave at VGS he can do them for you 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
