Home > Puma (Tdci) > Help ID these Sensors
big110
2014 Defender 110 Puma 2.2 SW Keswick Green
Can you help me ID these three sensors? The top black, and the below orange and green? I'm wanting to see if one of these is a pyrometers and one a boost sensor?
The green and orange look like they run under to the shifter area...
Thanks!
Post #580974 27th Nov 2016 10:36pm
Roy5695
They're to do with th dpf. One is a pressure sensor and on a temperature sensor.
The pressure sensor is to sense the pressure difference between pre and post dpf so it knows when it's getting blocked and needs to do a regeneration.
The temp sensors make sure it doesn't get too hot during th regeneration and also that its hot enough to begin one. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #580992 27th Nov 2016 11:14pm
big110
Roy- dpf?
Post #580996 27th Nov 2016 11:19pm
Roy5695
Diesel particulate filter.
Like a catalytic converter but worse as it clogs up then sets its self on fire to turn the carbon into ash.
Annoying but a legal requirement in many countries. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #580999 27th Nov 2016 11:21pm
