Home > My Defender > The White Camel - my 90 300Tdi
Arierep
Portugal 1995 Defender 90 300 Tdi SW Alpine White
Hi all,
This thread will about my 1995 Defender 90 300Tdi called White Camel. It's may daily driver and weekend toy, which I'm building as an overland rig.
This story will be told in media res.
It all started in February 2013. The White Camel was purchased new in 1995 by EDP, the Portuguese national electrical company (now Chinese...). They used it to maintain remote transformers and powerlines. Like most commercial Defenders of the time, this one was rolling on 205R16 tires and has a mostly untrimmed interior.
This is how how got it, and mostly, except for the snorkel, how EDP got it:
So, why buy a 18 YO company car? Mostly because it had NO RUST and a full LR workshop service history. Some bolts were missing, bushings were cr@p and plastics broken, but all easily repaired.
It was a daily driver and weekend offroader since the beginning, but the idea was to slowly turn it into a capable overlanding vehicle. Most preparation ideas came from the Camel Trophy vehicles, without ever wanting to be a replica, hence the White Camel thing
Post #580166 24th Nov 2016 6:40pm
Arierep
So, immediately after purchase, I started to renew it.
Tires were a priority, the one I got were tubed Portuguese 205R16 CAMACs. And yes, Portuguese tyres are a thing, supposedly very sought after by UMM collectors.
So I got a set of 235/85R16 BFG ATs. Being in a tight budget at the time, had to opt for cheap Modular rims 16x7 ET8, at �36 each. Surprisingly, these went rust free for 3 years, also being unbelievably air tight.
Also started to replace suspension bushings, renew pedal and gear lever rubbers and replacing missing body bolts.
When I learned about the thickness (or lack of) of the diff pans, immediately got a pair of these:
The Superwinch X6 was not working properly, so I ditched it with the bumper. Luckily, a guy restoring a Camel Trophy special edition Discovery 300Tdi was after one, so that was a quick sale.
Here is how it looked 1 month later, in it's first trip:
Post #580172 24th Nov 2016 7:21pm
familymad
Good looking 90 Thumbs Up 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #580175 24th Nov 2016 7:26pm
williamthedog
Nice truck
Nothing much wrong with it really. Thumbs Up
Post #580201 24th Nov 2016 8:19pm
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
I'm going to follow this thread Thumbs Up
Keep the story coming Laughing Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #580207 24th Nov 2016 8:24pm
Arierep
So, after the first upgrades, I proceded to install a Paddock galvanized steel steering guard. That was just me being cheap and avoiding to buy the Mantec one I really wanted, only to do so some years later.
After a couple of close calls with garranos (wild horses) in Geres, I decided I needed some basic front protection. Wanted a Camel Trophy type bull bar, but they are really, really rare in Portugal. Found a genuine LR bullbar close to me and pulled the trigger. Nothing heavy duty, but should protect the radiator and also the headlights from branches, etc.
Meanwhile, reversed into a light pole and bent in the rear door. Managed to repair it, but it was weakened in the process.
In order to avoid cracking the door I installed a Bearmach spare wheel carrier. It's a perfect copy of the expensive Mantec one, except for the cr@ppy paint job, which I redid myself.
And it was more or less done for 2013.
In 2014 and most of 2015 was also in a limited budget, so all the effort went into mechanical renovation.
Here's a small list of what was replaced (using only OEM parts):
- Radiator;
- viscous fan coupling;
- thermostat;
- "Y" cooling hose;
- expansion tank cap;
- front propshaft;
- rear propshaft;
- front transfer case output bearing;
- water pump;
- brake pads;
- every single suspension bushing;
- full chassis linseed oil anti rust treatment.
And that was mostly it
Post #580482 25th Nov 2016 7:27pm
CarMan
[/quote]
Bow down Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top (sold)
Post #580491 25th Nov 2016 7:45pm
Arierep
You are kind of making me feel bad, as it looks so different right now
Post #580495 25th Nov 2016 7:46pm
L110CDL
Good looking landy then and most probably now, thanks for sharing the info with us Thumbs Up Clayton.
Keeper.
Post #580705 26th Nov 2016 10:40pm
Arierep
Thank you guys
In late 2015 I had most of the mechanical overall done. Time for upgrades.
First was a set of HD steering bars with OEM TRE's. The original ones were reshaped at least 2 times. The HD ones should be standard, they are nothing over the top, more akin to what Japanese and Mercedes models come stock
Next was the steering guard. I never truly liked the steel one I had. Ended buying a Mantec guard, the one I always wanted.
Is reasonably light, very sturdy and protects as far back as possible. On the other hand, is not very friendly for tall suspension lifts since the front steering rod might hit the guard. For me is perfect.
In true LR / Mantec fashion, tolerances are all over the place, instructions are cr@p, some bolts are missing are other bolts are doubled. Easy to see how the two brands were buddies for so long.
Wanted to replace the tired suspension and played a bit around with different setups. Settled on:
Front - NRC9448/9 (130 fronts)
Rear - RKB101230/40 (90 HD progressive rears)
ANR2938 isolators on the rear springs
Genuine shocks all around
This gives a 1 or 1,5" lift when unloaded, a firm ride and a fantastic load capacity. It corners very good, even without sway bars. Offroad it has a hard time fully flexing unloaded, but given the true purpose of the White Camel this is OK.
PS: tried some different suspension setups and concluded there's no real need to lift a Defender unless you want to run 35" and up. Their stock suspension is already quite tall, more so than most of the competition like Patrols, etc
Post #580710 26th Nov 2016 10:59pm
Arierep
Next was the biggest investment so far, the mighty roll cage.
Keeping with the Camel theme, opted for the Safety Devices L142. It's the Camel Trophy model, but with rear stays compatible with the bench seats.
Other advantages:
- nearly 50% cheaper than other options;
- compatible with traditional roof rack;
- safe, as is has an actual internal loop.
It took me 40 man hours over 3 days to install it.
Also installed a Southdown snorkel by this time. It's a proper snorkel, goes direct to the airbox, ditching the tight and impossible to seal stock ducting
Post #582281 2nd Dec 2016 8:38pm
BossHog
Looking good Thumbs Up
Post #582369 3rd Dec 2016 11:20am
Arierep
Some interior upgrades followed
The original 20 year old steering wheel was falling apart, so I installed a rally style generic brand steering wheel. Some local guys have been racing this model for some time, and it's very durable.
The offset only works well with the next upgrade
Being 184cm I always felt a bit cramped in the Defender, mostly on the knees. There are plenty of aftermarket seat raisers on the market but they felt a little too expensive for what they are.
�10 of 30mm tube later and I got a pair of seat extensions made (and an extra pair for a buddy). They are 30mm tall (duh) and allow for the seats to be mounted 50mm back
Being sometimes a cheap b@stard, I rode for 2 years with the hi lift between the seats and the bulkhead. Not only very dangerous in case of a crash, it was also a total PIA to use.
The I maned up and got a 4XRAC mount kit.
Was planing to mount it along the left wheel box, but noticed it fits perfectly on the bulkhead, even with the roll cage loop.
Then we bought a companion for the Defender
It's a mint condition, very late manufacture 1998 Discovery 300Tdi.
Absolute pleasure to drive, super comfy and delivers over 35 mpg
Post #583378 7th Dec 2016 11:17pm
Arierep
Then it was time for proper shoes.
It was a very a tough tough decision, spent many months considering different tyre and wheel combinations.
I wanted rims with a reasonable offset, but wanted to keep the genuine LR look. Wolfs are, IMO, the prettiest of them all and can fit (with some good faith) up to a 285 tyre. With spacers they get equivalent to a -10mm offset, so thats about what I wanted. Also, being a standard rim (instead of some obscure sourced modulars with a specific offset) they're easy to replace.
On tyres, I wanted height, but had little interest in width. Checked the 285/75R16s but the height advantage to the 235/85R16 seemed small. Was even considering 35"s, but they were too wide. Also, measuring some units in the real world, they were barely 34" tall, so hard to justify the investment and disadvantages.
I'd go for 8.25R16 or 9.00R16s, but theyr are too rare and expensive.
Ended up choosing 255/85R16, specifically the BFGs KM2, as they where the cheapest ones here.
Pros
- narrowish
- not too expensive
- not too punitive to stock drivetrain
- keeps the LR look while improving performance
- tall
Off the car, at 2.5Bar on the Wolf rims, my units measured 33,5" tall. Most 35s I measured were about 34,2" or so, so we are talking about a 0,7" diameter difference here.
Old vs new
Please ignore the roof rack, it was a cheap Bearmach one I got to take some measurements to build a custom one (and yes, that bumper is "somewhat bent")
The Disco keeps getting smaller
Post #583801 10th Dec 2016 1:46am
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
Very nice indeed Thumbs Up Yes, laughing at you diminishing discovery Rolling with laughter 35 mpg you say, I had a 1998 auto which returned round about 20, maybe 23 on a run Big Cry , yours is obviously manual - I like the series one discovery very much.
Post #583820 10th Dec 2016 9:08am
