Home > Off Topic > Decent, affordable tap & die set? |
Can anyone recommend a decent, affordable tap and die set?
I've been happy with Dormer ones before, I haven't been happy with off brand ones that either go blunt or snap almost instantly. I'm after good value, not cheap! Obviously cheap is good but not at the expense of value (i.e. they have to be decent). I'm happy with things like Bahco socket sets and Starrett punches, things don't have to be Snap On or PB Swiss Tools. Something like this lot, they say they're HSS which is good? http://uk.rs-online.com/web/p/threading-tap-die-sets/5090143/ |
21st Nov 2016 1:36pm |
Thanks. Yes, hand use only.
They're not going to be used every day but equally I get sick being let down by bad tools. I've got a set of up to M12 Dormer taps at work which seem to be good. They're the general purpose ones that you can't tap all the way to the bottom of a blind hole with but that's not been a problem for my use yet. Maybe I'd be better off just buying individual ones and building my own kit up. It's occasionally useful to have some really odd sizes like the seatbelt bolt one which got me out of a pickle once. |
21st Nov 2016 4:46pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17427 |
Normally sets with multiple sizes include a "second" tap, which has less of a taper than a "first" or "starter". I usually buy individual sizes as required in a set of first, second and plug (the one for bottoming holes) but it does get expensive when you're working with metric coarse and fine threads, helicoil sizes, as well as UNC, UNF, BSF, BSW, BSPP, BSPT and one or two other thread systems.
21st Nov 2016 6:20pm |
I Have used Senator Tap and Die 's in the recent past always found them to be up for the job provided you drill the correct size and use cutting compound.
Found this from the company I buy from,https://www.cromwell.co.uk/shop/cutting-tools/metric-iso529-hss-gt-threading-sets/m3-m12-hss-threading-setin-case-32-pce/p/SEN0869980K, look familiar. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to us off. Richard |
21st Nov 2016 8:28pm |
That does look familiar, yes
Given they're HSS rather than carbon so probably not too awful (hopefully?), I might buy something like that, replace what dies and add a few other bits and bobs. Then the other half of me is saying buy cheap, buy twice, just get the Dormer ones. |
21st Nov 2016 10:19pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
I have got a few of these sets and they seem a good balance of value and quality.
http://www.rdgtools.co.uk/acatalog/TAP_DIE_SETS.html Would prefer Dormer though Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
21st Nov 2016 10:30pm |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629 |
I have used Dormer for years also drill bits. Always look for them at auto jumbles .
21st Nov 2016 11:38pm |
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 627 |
The RS Eventus set is probably Polish made. When I worked for RS the Polish tools were good basic workshop items. HSS is fine for hand tapping in most workshop applications. It is only once you are going to production speeds and exotic materials that you need the coated tools. 1995 Defender 110 CSW
1971 SIIA Lightweight |
22nd Nov 2016 9:12am |
Riccarton Member Since: 10 Aug 2015 Location: Gods' Own Country Posts: 280 |
Unfortunately I'm of the opinion Dormer aren't what they used to be.
We buy fecking hundreds of M6, M8, M10 & M12 (first cut) - all of them dormer - and they just don't last nor do they cut as well as my memory serves. Privately I've always liked the Wurth set father has but they aren't easy to get hold of individually. |
22nd Nov 2016 10:00pm |
