Home > My Defender > My V8 90 Auto rebuild.
Page 24 of 31 <123 ... 232425 ... 293031>
Thanks Shane.
How's yours coming along?
Post #578839 18th Nov 2016 9:23pm
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
new arrival now 4 months old, been 4 months since I've been at the defender, have been collecting parts and hoping I might get out over the Christmas holiday. Would be great to be on the road next summer, that will be a 4-year build lol
Post #578913 19th Nov 2016 10:29am
4 years! I haven't got that much patience!!
Post #578920 19th Nov 2016 11:38am
CY88
1986 Defender 90 V8 Petrol ST Keswick Green
GREENI wrote:
Looking great, Greeni Thumbs Up
Eyes peeled for when the canvas goes on!
FFRR Supercharged - Series One - Defender 90 V8
Post #579118 20th Nov 2016 1:12am
Thanks. It'll be going on soon Wink
So just a few minor details to sort before MOT time.
The GEMS benefits from an obd port, so I decided put it in this housing to go in the seatbox
Literally only needs 3 wires Shocked
Then I have an issue to sort.
The engine starts but doesn't switch off. Apparently the ECU is pulling a live from the alternator, so it seems I may need a diode going in somewhere.....anybody any idea? Embarassed
Post #579165 20th Nov 2016 11:41am
dorsetsmith
up date if you look ^ see very basic wiring for starting and stopping and charging much same as your 85 90 defender dash wiring
point A start the ecu power up and also power down
with the alternator excitation cct power from point B in the cct and not diode fitted ecu has no way switch off and stop the engine
Post #579173 20th Nov 2016 12:35pm
Thanks Dorset, trouble is the 90 was originally a '85 4cylinder petrol, so I don't have all the harness etc Crying or Very sad
It's beginning to grind me down!
Post #579217 20th Nov 2016 5:13pm
dorsetsmith
your wiring shroud same as 200tdi wiring but instead wire too fuel stop sol in the fuel injector pump go to the coil
turn your key to off and you stop making spark at the plugs engine stops running, I no not 200tdi but good start
it from V8 with no ecu and coil and disturber, but if you had ecu wired in the same place as the coil you can see how your problem will hap on if no diode is fitted in the alternator excitation cct to prevent 12 volt back feed from alternator
Alt has diode in the excitation cct to prevent 12 volt back feed from alternator on engine stop when key is switch to off
diode 4 amp rating
i am going to stop reading post on my phone Embarassed on the PC it all make sync
v8 pdf schemes
http://www.legionlandrover.com/manuales/el...r%20v8.pdf
my hats off to you Bow down getting it to start and run, tacking me back to my prototyping days with dorman engine and gas engine electrical control up grade
Post #579227 20th Nov 2016 5:59pm
dorsetsmith
LR have missed things on the drawing read below
LR charger FDS reads alt havering diode in the exciter cct wiring
Post #579378 21st Nov 2016 9:47am
Thanks very much, I'll be stripping the steering column off very shortly together to the whole of the dash. Thanks for your searching, I really appreciate it. I also noticed you doing these things helping people out here and there on here. Thank you.
Post #579498 21st Nov 2016 6:20pm
Dorset, I'm assuming you know quite a bit about electrics as you listed the 4 amp diode... do you know how/where I could get hold of one if possible?
Post #579852 23rd Nov 2016 1:22pm
dorsetsmith
Diode
Maplin 6 amp 600 volts working see link
http://www.maplin.co.uk/p/p600j-6a-silicon-rectifier-uk61r
Post #579859 23rd Nov 2016 2:40pm
Wow, thanks. Got home, saw your post, ran out, drove to Maplins, picked up diodes and will attempt to fit them later.
Thank you Bow down
Post #579907 23rd Nov 2016 6:42pm
dorsetsmith
that`s not problem manage to get two spring and two head light fitted today and front ones tomorrow Thumbs Up
Post #579918 23rd Nov 2016 7:31pm
Cut the front springs off Thumbs Up
Post #579919 23rd Nov 2016 7:37pm
