Home > In Car Electronics > Trailer Warning Lamp Stays On
PeterG
South Africa 2011 Defender 110 Puma 2.4 SW Alaska White
Hi all
Please forgive me in advance if an answer to this presents elsewhere
I have a 110 Defender (2011 Puma)
Driving on a fairly lengthy gravel road yesterday (about 400km) the trailer lamp on the dashboard, which normally only illuminates when my 4x4 trailer is connected (which it wasn't) came on and now remains on when the vehicle is running, despite the trailer not even being connected or my not using the indicators at all.
I'm totally confused as I haven't changed any bulbs or fiddled with the electrics at all.
I connected the trailer this morning and the trailer lights worked perfectly but when I disconnected the trailer the trailer warning lamp still remained on.
I'm not electrically/ electronically educated at all and intend to take it in to an auto electrician, but before I do so, has anyone else experienced this/ have any advice?
Peter
Post #579194 20th Nov 2016 3:26pm
VeeTee
Netherlands
You may have a faulty Flasher unit. (YWT500050 - RELAY FLASHER UNIT)
Could be loose internal contacts or short circuit due to vibrations. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #579201 20th Nov 2016 4:07pm
dorsetsmith
Check trailer socket back for water to start with
Post #579202 20th Nov 2016 4:09pm
PeterG
Thx guys
Will revert once established
Post #579230 20th Nov 2016 6:08pm
JAY BOY
Wales
See if your flasher unit has a little knob on it. if it has turn it a little to turn the trailer light off.
Post #579234 20th Nov 2016 6:18pm
PeterG
Hi guys
Thx so much for all your insights.
I've gone as far as replacing the entire trailer connector at the back of the vehicle (as I did find water in it), but despite this and the fact that all the flickers and light functionality on both the Defender and the trailer are perfect, the trailer warning lamp on the dash still remains permanently on when the ignition is turned on.
It's booked to go in to my local Land Rover specialist tomorrow morning.
I'll let you know the outcome in due course.
Peter
Post #580134 24th Nov 2016 4:25pm
PeterG
Hi again
So in it went on Friday and as they couldn't find the problem I was requested to take it in again today.
I got it back, late this afternoon.
It was established that there had been a short in the wiring in the main loom under the vehicle which had also caused the relay to require replacement.
All sorted!
Thx again for all your insights.
Peter
Post #581124 28th Nov 2016 4:41pm
