Home > Td5 > My defender has just been sick in the office car park |
Motoberg Member Since: 01 Oct 2015 Location: Aberdeen Posts: 104 |
Oh dear, a 2 foot yellowy liquid puddle has evolved on the floor under the engine.
Checked the expansion tank which needed water but by no means empty. If something had parted surely it would empty the entire contents of the cooling system on the floor ? weird ? |
15th Nov 2016 3:26pm |
xcentric Member Since: 17 Jan 2016 Location: Midlands Posts: 247 |
sounds more like urine than vomit to me
15th Nov 2016 3:40pm |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Did you check your brake fluid?? 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered. |
15th Nov 2016 3:41pm |
good point
15th Nov 2016 3:47pm |
No idea, need to get it in bits at the weekend to find out, of course the MOT is due on Monday
16th Nov 2016 3:52pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
Are you sure it wasn't there when you parked and you didn't notice?
Speaking from experience, err, a friend had Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
17th Nov 2016 12:43pm |
unfortunately not, we have numbered spaces at the office so my bus is the only thing that parks there
17th Nov 2016 3:55pm |
Happened to me some years ago with a Range Rover Classic that had been stood for 12 hours, a great puddle of reddish liquid had appeared under the engine . Had a quick look round but didn't dare move it so walking home at 03.00 am after wasting an hour in the pouring rain. Next day called out a recovery to take it to the dealers who spent 4 days searching and swapping parts out just in case ( Oh yes and running up a bill) they couldn't find anything, it was a good job I have a warranty from them. A week later the security team came back to working with my shift and one of them tells me in passing how he dropped a raspberry frozen lolly on the floor of the car park the last shift he worked with me and had kicked it under a car so nobody would step in the remains. Oh how we laughed .
I laughed last when I sent him the bill for Taxi's and a mocked up bill from the dealers in total £2500.00. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to us off. Richard |
17th Nov 2016 4:14pm |
had coolant leak on 2003 td5 left hand side for engine small amount would run down to ledge at bottom engine block only leak then engine cold, it tuned out to be 1nich plug in between exhaust ports on the head 3 hr fix 3 gasket and 13mm nuts
heater matrix top end seal leaking it would drain down coolant expansion tank to the same level and heater out put cold new heater matrix old stock MOD part 1997 raped in brown paper and brown box too, sorted still good to day also early type fuel cooler can leak too driver side engine round tube about 5 inches long the O ring perish at ether end |
17th Nov 2016 5:01pm |
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 |
a friend of mine had his engine out twice trying to sort a rear crank seal leak; he thought he had sorted it until the next morning when there was a large pool of oil under his bell housing... what he didn't know is one of us poured it there on the way back from the pub... how we laughed when he thought the engine had to come out again.
18th Nov 2016 7:14am |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4794 |
Looking at your avatar it looks like your vehicle has aircon. The gas contains a yellow/green liquid that is there to highlight leaks and show up in the event of a crash. Check that your aircon is working too 2002 90 Td5 Station Wagon
18th Nov 2016 8:38am |
I'm impressed you can tell it has aircon from my avatar !! Is green stuff leaking out in the photo too ?
The aircon compressor was removed for some reason by the previous owner so it has an 'pipes open to atmosphere' system |
18th Nov 2016 11:10am |
2 bolt union under the power steering pump had come slightly loose.
Luckily it was an easy fix ! |
19th Nov 2016 4:39pm |
