Home > Maintenance & Modifications > Positioning of Lazer light RS-4 lights
Page 2 of 2 <12
Sulisuli
Vee Tee your a gent, I have searched in vain to discover what they were and now I know......that will make the ebay listing easier Very Happy as I have ordered today a pair of Jw speaker evo ll , so this time next week I should be able to see some what better, if not Im off to specsavers next Laughing 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #578779 18th Nov 2016 6:47pm
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
Morepower wrote:
Our 110 has a set of Noldens (supplied by Brendan at 4x4 Overland) and they are great, However they need careful setup to get the best out them.. i.e alignment... I believe Brendan also supplies a small headlamp loom that enables the high beam function to use both lo/high headlamp outputs...
Hmmm, I was very interested in this; I have Noldens too (from Brendan of course) and wondered what this loom was.
Vision-X make it and that's what Brendan used to stock. However Brendan hadn't had chance to test it to see if it worked with the Noldens. In short, as far as I can tell it definitely won't work with Noldens because the electronics inside the light extinguish the dipped beam if the main is lit, no matter what you do with the main/dipped 12V feeds.
The first thing I tested was whether on 'flash' the Nolden dipped beam was on or off. It's off as expected.
So, either the switch does that or the electronics in the Noldens do. So I had a look at a spare switch; all the contacts are out in the open so easy to examine.
The dipped/main switch is a one-or-the other, but on 'flash' (pulling the stalk towards you) it leaves the dipped on but also puts the main on.
This would work with a normal H4 bulb just fine and illuminate both filaments. However the Noldens electronics definitely switch off the dipped beam if the main beam is on. I guess this is a heat-management technique. I know LED Speaker Evos are a one-or-the-other design too. I guess Vision X lamps will work with this adaptor given they make both. Dave
Green Goddess - 1998 Defender 110 300tdi
Post #578818 18th Nov 2016 8:30pm
Morepower
New Zealand
That's good to know Dave.. saves me spending more money..
Rolling with laughter
Cheers Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #578881 19th Nov 2016 8:02am
Darcy Fairfax
England 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
Riverboy wrote:
Or go the whole hog and have RS-4s in the grill, ST-4s inset into the bumper and a Triple-R 24 up top Wink
and then stick a couple of T2s on the rear so you can see going backwards Whistle
I think you can see me from space Laughing
Man alive, it must look daytime when that lot are on! Thumbs Up
Post #578885 19th Nov 2016 8:24am
Riverboy
2014 Defender 90 Puma 2.2 SW Corris Grey
It does Very Happy Mind you, the top one is off road only. Its very handy if there's a power cut and I need to bring the horses in etc. Thumbs Up
Post #578897 19th Nov 2016 8:59am
PWC1c
United Kingdom 2015 Defender 110 Puma 2.2 SW Auto Santorini Black
Hi with the RS-4 in the bumper do you need the trip-R24 is it over kill ?
Post #578927 19th Nov 2016 12:01pm
Riverboy
For most people probably yes, but I wanted as much light as possible. I live in the foothills of the Alps and have horses. Its very dark around here so having a vehicle that can light up large areas is very useful. Thumbs Up
Post #578935 19th Nov 2016 12:36pm
PWC1c
I will be using my Defender for driving to the ALPS and around for skiing the roads are that bit darker so the bumper option looks if it will work
Post #578941 19th Nov 2016 1:15pm
Riverboy
Thumbs Up Yep they are fantastic for the roads here. You really do want to be able to see where the edge is because its a long way down Shocked
Post #578943 19th Nov 2016 1:31pm
PWC1c
Do you get Glare off the the bonnet with the tripe r
Post #578946 19th Nov 2016 1:44pm
Riverboy
No never noticed any. It tilts so you can adjust it if its too low or high.
Post #578957 19th Nov 2016 3:06pm
Defender2014
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Santorini Black
Defender2014
The Vision X units do indeed bring both low and high beam on at the same time if using the adapter lead.
Have this setup on mine.
If you buy the Vision X units from TMD they chuck the adapter lead in FOC. At least they used to....... Defender Puma 110XS SW
Kawasaki ZX9R El
Suzuki RGV250M
Honda CB250N Super Dream
Post #578974 19th Nov 2016 4:06pm
Page 2 of 2 <12
