Home > Wheels & Tyres > Swapping Alloys for steels over winter
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
I am considering swapping the Boost Alloys and tyres that came with the 110 for a set of steel rims and winter tyres, possibly a set of Challenger 16x7's.
No being totally ignorant when it comes to wheels and tyres with the exception that they go round and need to be legal, I have a question.
I read somewhere on the forum that that alloys and steels are different thicknesses , Do I need to swap the wheel studs ? Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #578470 17th Nov 2016 3:42pm
pjb
I do not think studs but the nuts are different so will need a set of steel wheel nuts Thumbs Up 2020 P300 HSE
Post #578477 17th Nov 2016 4:09pm
mse
You can use alloy nuts on steel but not the other way round...although they will stick out and look odd Mike
Post #578479 17th Nov 2016 4:19pm
ARC99
Are yes new nuts I had forgotten about those. Good catch.
In my pervious job we were allowed to change wheels on the firms vehicle but not to drive them until we had had the nuts checked by a mechanic, we must have had one of the first female mechanics and the lads on the shift were always changing the wheels and asking for there nuts to be checked. Don't make old people mad.
Richard
Post #578480 17th Nov 2016 4:22pm
ARC99
Do you mean stick out and look odd as in silver against black?
or
Protrude out from the wheels? Don't make old people mad.
Richard
Post #578493 17th Nov 2016 5:31pm
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
Standard steel wheel nuts are basically just that - they look like nuts. The nuts for your alloys are taller / deeper made and possibly have domed tops to them. They will work fine on the steels although they will look 'big' against the wheels and stick out a bit - personally I don't mind the look on the likes of a set of black modular. If you are changing over to HD or 'wolf' wheels I believe you will need longer studs as these rims are thicker. There should be stuff on here about it, but no doubt someone will be along shortly to either confirm what I suspect, or tell me I'm talking rubbish - either is very possible.
Post #578495 17th Nov 2016 5:47pm
DSC-off
To make things easier, you could get some "take off" alloys for the winter. There are plenty of boosts around for less than you'd pay for the challengers.
No need to buy nuts, or carry a set of alloy nuts in case you need to fit the spare ( assuming you don't get 5 steel wheels + tyres).
Probably better quality wheels too...
Post #578522 17th Nov 2016 8:07pm
Cupboard
ARC99 wrote:
In my pervious job ... nuts
Laughing
You're entirely correct in that there are longer studs and that best practice would be to swap them, however almost no one does and they're fine with the standard studs.
Post #578530 17th Nov 2016 8:40pm
cobra_mark
United Kingdom 2000 Defender 90 300 Tdi SW Barolo Black
I use steel wheels over the winter, have alloy free style wheels for the summer non salt time.
Give me time to clean up the alloys. Smile
Post #578533 17th Nov 2016 8:44pm
