Home > In Car Electronics > Led side and rear
RNBS
Led side and rear
Ok, done a search and admittedly I'm confused, what leds can I use without any problems for a defender 2.2 tdci ? Front side lights and rear lights? Exclamation
Post #578011 15th Nov 2016 8:20pm
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I got mine from Mud Stuff.. Work great and look pretty cool too... I wouldn't mess with LED bulbs..
It's LED indicators that cause issues.. They need a proper LED flasher relay, or a bloody great resistor to work..
If you get LED indicators, get the proper relay, so much less aggro!! ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #578036 15th Nov 2016 9:40pm
You can change them all with no issues even the side repeaters.
It's front and rear indicators that you need the Relay for.
Even then, easy to sort out no problem. KEEP CALM AND Drill ON
Post #578060 15th Nov 2016 10:38pm
Screbble
I'm with Steve on this.
A doddle to fit and the difference is amazing - especially on dark country lanes.
Get the flasher relay - particularly if you intend to tow.
I got mine from Bolt On Bits (RDX) via eBay and never looked back Thumbs Up
Post #578100 16th Nov 2016 7:12am
It's just best with front and rear indicators to fit the full set front and rear and Relay at the same time in my view.
The rest you can change bit by bit when ever you like.
I fitted LED's to mine in stages, mainlu due to getting some @ Xmas given to me etc. KEEP CALM AND Drill ON
Post #578163 16th Nov 2016 12:27pm
