Home > Technical > Electric front window not straight at bottom
neverin
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Stornoway Grey
As the electric windoew gets towards the bottom it tilts . i have taken the door card off and the mounting panel moves when the window goes down almost as though the mechanism isnt set up propoerly. is there a setup diagram or manual for setting the mechanism up. the whole door has recently been replaced with a new one.
any pointers?
Post #577569 13th Nov 2016 7:09pm
dorsetsmith
The track with two 8mm fixing the class fix too must be a to move free as the window gets down in side door bottom play you to remove door card see how to is snagging
also make shore the two class guide are free of for loss fix screw
Post #577578 13th Nov 2016 7:35pm
neverin
THanks for the reply. do you know of any instruction on how to set the mechanism up or should it just be fitted with the two bolts secured to the black door plate and then adjusted as necessary. Also the glass channel runner kept moving up and down with the window so i have had to put a screw into the top to keep it there.
Post #577625 13th Nov 2016 9:27pm
dorsetsmith
glass channel runner is screw into place if you run small screw driver up down slots you will find pre drill holds in glass channel runner 3 pre side and three across top and one at the bottom both sides
had same problem with replacement doors i had to fit and fond screw jamb up side down in the channel
im looking pic showing it in place
Post #577645 13th Nov 2016 9:49pm
dorsetsmith
6 fixing pints
Post #577676 13th Nov 2016 11:06pm
