Home > Td5 > TD5 2001 Servicing
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
TD5 2001 Servicing
Hi, I'm looking at servicing my TD5 in a few weeks and I'm putting together all the parts I need. With regards to the engine oil, whats the "best" one for my Truck. Its done about 50k.
I've looked at the site sponsor (Advanced Factors) and they would supply Mobil 5x30 oil.
This would be the first service for the TD5 since I have owned it. Although the service details are up to date (Private garage, Ex Water works truck) would it be worth while changing ALL the fluids while I'm at it; Power steering, Front diff, gearbox, Rad etc?
I'm not looking at wasting money so if there is no good reason then I won't. I'm thinking if I did I'm then on a level playing field so to speak. Thumbs Up Dog
 Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #577104 11th Nov 2016 12:57pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
If this is the first service since you've owned it, personally, I highly recommend changing all fluids... this way you will absolutely know what is what and have great baseline. All fluids are specified in the owners manual and shop manual.
Gearbox MTL 94 or ATF (just change what is in it if it shifts well)
T-case 90Wt
Swivel balls (one shot grease)
Diffs 90Wt
Steering fluid
Coolant (pink/red)
Brake fluid (often overlooked yet extremely important)
Engine (fully synthetic)
 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #577115 11th Nov 2016 1:21pm
dorsetsmith
Service check sheet 1999 to 2001 TD5 defender (Wessex water and south-west water work to this sheet with there land rover )
http://www.web-rover.co.uk/images/td5kb/service99my_huge.png
http://www.screwfix.com/p/green-pressure-s...kpid=51100
pump up sprayer is good filling gear box with oil
http://www.ebay.co.uk/itm/OIL-COOLANT-GEAR...Sw8w1X5Qq4
link to good size drain pan for engine oil, gear boxes too
Also if brake fluid changed do clutch fluid at same time !
Post #577117 11th Nov 2016 1:24pm
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
I used a PD (pump deuce ... not sure on spelling) specific oil.
Whilst not a written requirement, the logic in my head made sense. The TD5 unit injectors are essentially the same theory as the VAG PD's.
Made sense to run that.
I'm a bit of an avid Mannol oil fan to boot, so that's where it came from (unless I couldn't get hold of it, then I ran Com-Line PD).
Post #577122 11th Nov 2016 1:50pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
When I first did mine I changed all filters and oil, coolant, axle oil, gearbox oil and differential oil. Also, put a new ancillary belt on it.
Used genuine filters and recommended oils Very Happy
Post #577171 11th Nov 2016 6:33pm
MC84
Thanks for all the input. Looks like I'll change all the fluids this time round then. The choice of engine oil, any input there? Which is the best fully syn oil? Mike
Ford 100e 1959
Post #577238 12th Nov 2016 5:01am
Tommo
Initially used Castrol magnatec 5w-30 fully synth (a5), but now use shell helux af 5w-30 fully synth.
Both are good!
Post #577261 12th Nov 2016 9:24am
MC84
Thanks for the links and suggestions. Purchases made!!! Thumbs Up Thumbs Up Thumbs Up Mike
Ford 100e 1959
Post #577435 13th Nov 2016 12:10am
jrule
United Kingdom 2000 Defender 90 Td5 CSW Oslo Blue
I'm hoping to do the same shortly, following this one!
Post #577443 13th Nov 2016 7:03am
Screbble
As others have said, I'd change the majority if not all of the fluids and consumables.
None of the work is particularly challenging, and none of it is prohibitevely expensive.
You'd be starting from a known baseline/benchmark then.
The information available on this forum (just search individual servicing tasks) will make the job ten times easier. I have learned a lot from my fellow members and saved heaps of time and energy (thank you).
Check out Opie Oils, another site sponsor - they'll give you top notch advice and a forum discount to boot.
Personally, I'd stick with genuine filters and consumables Thumbs Up
Post #577474 13th Nov 2016 10:32am
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Don't forget 2 oil filters on a Td5 and be careful with the 2 bolts on the rotary filter ..... I'd also change out the injector wiring harness too Thumbs Up
N.
Post #577478 13th Nov 2016 11:16am
MC84
Another question, I've gone and got all the oils I need for the truck, I've opted for Comma as they are easily available.
One doubt I have however is what their system recommended for the Transfer box. Land Rover say 75W90 but the motor factor said 80W90.
http://www.commaoil.com/passenger-vehicles/products/view/183
This is what I went for but i've not put it in yet, just in case!
http://www.commaoil.com/productsguide/view/6/182/SX5L
Is this what I should have gone for? It's a semi synthetic not a mineral.
http://www.commaoil.com/passenger-vehicles...81/SXGL45L
Perhaps the motor factors were right with the first one buts its a 80W90
Any advice very welcome.... Mike
Ford 100e 1959
Post #579087 19th Nov 2016 9:44pm
4RF RDS
Recommend you keep mineral fluids in transfer case. Sythetics can cause it to leak where it did not before. Go with Land Rover recommended viscosities. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #579180 20th Nov 2016 1:16pm
miker
On Engine oil for the TD5, I use quantum Platinum 5w/40 in my PD130 engined Ibiza, do people think that would be suitable for the TD5 as well? Saves me keeping 2 oils in stock.
My Def handbook says 5w/30, 5w/40 to meet ACEA A1/B1.
Or I go the other way. Looks like Mannol PD oil meets VW 505 01, so would work in the ibiza. £56 for 20L too.
Post #579336 20th Nov 2016 11:09pm
