Home > Td5 > Heater Output poor
Motoberg
Heater Output poor
My heater output is about as warm as a glow worms derriere
Is this just a TD5 foible or is there something (easy & cheap ) I can do about it?
Even when the engine temp is just below half way ( normal ) it's warm at best.
Where's me coat.....
Post #577092 11th Nov 2016 12:11pm
bogwert
Scotland 2003 Defender 90 Td5 CSW Zambezi Silver
Have a quick check for any stretch on the wires from the controls to the box.
If they are stretched or the fitting is loose the rod wont be turning as much as it should when you flick the lever down. Thus not being on fully.
After writing this I'm second questioning if the heat is a setting by wire, but worth the check anyway! Thumbs Up
A wee guide to the correct wire. no. 13
http://new.lrcat.com/#!/1228/12822/13493/1049/13536 Chris
2014 Discovery 4 TDV6 HSE
2003 Defender 90 TD5 CSW
Post #577096 11th Nov 2016 12:21pm
bob neville
I followed the first post on the link below and it sorted the heater on my TD5.
http://forums.lr4x4.com/topic/33481-feelin...ntry323899
2013 Defender 90 CSW - sold
Post #577098 11th Nov 2016 12:33pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Be sure to check your thermostat operation as well. If not operating properly, you wont get much heat. it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #577174 11th Nov 2016 6:46pm
Screbble
Re: Heater Output poor
If all of the points above are addressed, it should be really, really warm. Yes it'll never be as good as the Puma or newer cars, but if the cables, levers, thermostat etc. are all spot on then it'll be good enough Thumbs Up
Definitely worth spending a bit of time checking everything moves that should - and you may need a helper.
I actually find mine very efficient (except for demisting the side windows) and it's been spot on over these past few colder days.
Hope you sort it.
Post #577185 11th Nov 2016 7:47pm
JWL
When they're working well they are good, infact I find myself backing the temperature off on mine and that's in a 110 station wagon! You will find that in traffic the heater output isn't as good as general normal driving
Post #577201 11th Nov 2016 8:52pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I fitted a new fan and a bilge blower into the inlet on mine and a hi flo inlet. With it properly adjusted so it gets full heat it all makes quite a difference.
I do have to wait for it to start reading a temperature before turning it on full, otherwise it never gets really hot.
It really is plenty now 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #577211 11th Nov 2016 9:38pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Could also be a sign of head gasket gone so check that too 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #577221 11th Nov 2016 10:44pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
The Td5 heater is more than adequate when properly sorted. Check everything listed in previous answers and make sure it is set up correctly. If you still have little to no heat start looking at the engine (head gasket, thermostat etc). I drive mine everyday and winter here is minus 20c or lower and I get heat enough to clear the windscreen and warm the cab (110 CSW). For more heat I also have a Wabasto diesel heater... yes the heater gets hot without it turned on. I also installed the digital fan control switch which spins the stock fan a lot better with more airflow. See info on this install here: http://www.defender2.net/forum/topic42251-15.html
In short, the heater should work well enough, its not normal to be tepid rather than warm to hot. Good luck. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #577278 12th Nov 2016 10:27am
Motoberg
Thanks all, will report back my findings Thumbs Up
Post #577461 13th Nov 2016 9:29am
