Home > Td5 > Part numbers for swivel overhaul.
Welkman
Hello all,
I cannot seem to master the microcat. I need all the seals and bearings/races to completely overhaul my swivels 2005 TD5 and also a non abs CV joint.
Any idea on the part numbers? Also what is needed to convert from TD5 spec bearing preload to the conventional twin nut preload setup?
Can you buy a parts book with exploded diagrams etc?
Thanks
James
Post #576114 7th Nov 2016 8:37pm
Romadog
Yes you can buy a parts manual - I have one and find it very useful
Need to google the part number.
See link below to parts on line - think its what you want?
http://lrcat.com/#31/4/52605
Post #576120 7th Nov 2016 9:26pm
agentmulder
Kuwait
I did this recently with my puma, including the two nut replacement.
No part numbers but a good start at understanding all the parts:
Parts can be found via https://www.landroverworkshop.com/parts and similar - for instance:
https://www.landroverworkshop.com/diagrams...0455_52606
https://www.landroverworkshop.com/diagrams...afts_52600
Check your cars VIN for the correct parts range. Solved the bowel problem, working on the consonants...
Post #576167 8th Nov 2016 4:51am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Here you go! http://www.allbrit.de/UNI.cfm?PAGE=755142&SPRACHE=EN 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #576230 8th Nov 2016 12:38pm
Devon-Rover
Ok Per side you will need VVV
Top swivel pin assembly: - NON ABS TAR100040 (Kit inc bearing and seal)
Bottom swivel bearing: - 606666
Gasket Stub axle: - FTC3648
Gasket Inner swivel housing to axle: - FTC3646
Swivel housing seal: - FTC3401
Inner swivel housing shaft seal: FTC3276
hub gasket: - 571752
Inner hub seal: - FTC4785
Swivel housing grease (one shot): - STC3435
You will need to remove the inner bearing spacer and replace the single nut with:
Locknut X 2: - FRC8700
Lock tab washer: - FTC3179
CV joint: - TDJ000010
There are kits which will cover it but you won't get the control over the quality of the bearings / seals it's up to you and your personal feelings.
Hopefully saves you a little time ferreting through the books.
Post #576259 8th Nov 2016 2:03pm
agentmulder
Kuwait
Off the top of my head, a few more gaskets required than ^^
Also to get at seal '23' you needed to ruin the roller bearing '16' - well, me and my knuckle headed approach did Razz
After doing all of mine I realised I should have really done the bottom pin ('20') as well.
Part '15' will need checking too, if there are no more holes left to assist in distributing lubrication then it should be replaced too (you'll see what I mean if they're there), it's a plain thrust bearing that wears as it goes along. The slop is accounted for in the shims '12', which you should get a few options so that you can pack it out snugly.
The shims for the swivel pin pre-load come with the kit for '20', but keep the old ones as I needed a couple more than I was given to make it work.
May as well do brake rotors and bearings while you're there too huh?
Hopefully your stub axle faces are nice... Solved the bowel problem, working on the consonants...
Post #576434 9th Nov 2016 2:01am
Welkman
Thanks for all the help. I have stripped the drivers side down and the swivel pin bearings had both collapsed, the cv joint is dry and knackered as well. As I have owned it for two years and not noticed any leaks I guess it has been dry for a long while. Luckilly the wheel bearing and stub axle are fine. Discs and pads are getting changed along with the pipe feeding the caliper. I might strip, clean and rebuild the calipers as well. Funny how a small job always seems to get huge !
Post #576601 9th Nov 2016 7:53pm
agentmulder
Kuwait
^^ yip, I did the caliper piston overhaul too Smile
You're pretty much forced to with the new rotor (and pads) as the dirty piston may damage the seals when you plunge it in to fit the wider parts.
Have fun doing the full bleed, lots of fluid, once it was all clean and only bubbles remained I made a recirculating circuit to save $$.
Managed to not mangle the flex>caliper pipe which was nice, I can see how easy it would be to kink it in the process.
Wow, they had collapsed ? That must have been an interesting driving experience, wobbles/slop?
Have a good read of the WSM regarding the required pre-load on the new set up, I didn't use a spring scale, but borrowed my mothers kitchen scales and pushed instead of pulled Rolling Eyes Laughing - got me in the right ballpark.
I managed to shear off a well corroded swivel seal bolt, had to get creative getting the remaining thread out of the hub. Also one flange was 'rust-welded' to the CV - got creative with the angle grinder to sort that Razz
Keep us updated Thumbs Up Solved the bowel problem, working on the consonants...
Post #576608 9th Nov 2016 8:11pm
Welkman
I thought the shaking was a wheel weight fallen off but I knew the CV joint was bad ! Also found both steering rods were bent. Sumo bars going back in.
All parts ordered tonight from several places so thanks to all that helped with that. I just cant see the bearing races for the swivel bearings listed...... they may come with the kit for the upper pin but not the lower one?
Post #576683 9th Nov 2016 10:22pm
Welkman
Well this is turning into a bit of an expensive job. Both track rods were bent, the discs were knackered and the pds have seen better days. Swivel balls are also well past saving. Check out the condition of the bearing races for the swivel pins !
New OEM balls ordered and a whole load of non britpart seals. Housings have all been cleaned up ready for a coat of chassis black and everything else cleaned and ready for reassembly. Next job will be the brake calipers.
Post #577573 13th Nov 2016 7:13pm
